Get Snapshot from Hikvision Camera
(13.03.2023, 12:51)admin Wrote: Are you sure that this uses Basic auth but not digest?
I´ll try it with digest first. I wroute in the post "Email with attachement" but you tell me to try with basic auth. But this post is very old and I create a new more specific.
Trying with digest auth this is the result:
* arg: 1   * string: <!DOCTYPE html> <html><head><title>Document Error: Unauthorized</title></head> <body><h2>Access Error: 401 -- Unauthorized</h2> <p>Authentication Error</p> </body> </html> <!DOCTYPE html> <html><head><title>Document Error: Unauthorized</title></head> <body><h2>Access Error: 401 -- Unauthorized</h2> <p>Authentication Error</p> </body> </html> * arg: 2   * number: 401 * arg: 3   * table:    ["server"]     * string: webserver    ["content-type"]     * string: text/html    ["connection"]     * string: close    ["date"]     * string: Mon, 13 Mar 2023 10:37:01 GMT    ["x-frame-options"]     * string: SAMEORIGIN    ["www-authenticate"]     * string: Digest qop="auth", realm="IP Camera(F0849)", nonce="5a6d566c5a475a6d59324d365a474534596a67794d6d493d", stale="FALSE"    ["content-length"]     * string: 178
And the code is:
local url = 'http://user:Pass@'..IP..'/ISAPI/Streaming/channels/101/picture' function SnapshotCamaraIP (url)     --Meter url de la camara http://admin:pass@"IP"/snapshot.jpeg   local skthttp = require('socket.http')   local skturl = require('socket.url')   local ltn12 = require('ltn12')   local md5sum = require('encdec').md5   local hash = function(...)     return md5sum(table.concat({...}, ':'))     end   local parse_header = function(header)     local result = {}     for key, value in (header .. ','):gmatch('(%w+)=(.-),') do       if value:sub(1, 1) == '"' then -- strip quotes         result[ key:lower() ] = value:sub(2, -2)       else         result[ key:lower() ] = value       end     end     return result             end     local make_digest_header = function(headers)       local digest = {}       for _, header in ipairs(headers) do         if not header.unquote then           header[ 2 ] = '"' .. header[ 2 ] .. '"'         end         digest[ #digest + 1 ] = header[ 1 ] .. '=' .. header[ 2 ]       end       return 'Digest ' .. table.concat(digest, ', ')     end local _request = function(req)   if not req.url then     return nil, 'missing url'   end   local url = skturl.parse(req.url)   local user, password = url.user, url.password     --log(user,password)   if not user or not password then     return nil, 'missing credentials in url'   end   url.user, url.password, url.authority, url.userinfo = nil, nil, nil, nil   req.url = skturl.build(url)   local source   if req.source then     local chunks = {}     local capture = function(chunk)       if chunk then         chunks[ #chunks + 1 ] = chunk       end       return chunk     end     local chunk_id = 0     source = function()       chunk_id = chunk_id + 1       return chunks[ chunk_id ]     end     req.source = ltn12.source.chain(req.source, capture)   end   local body, code, hdrs = skthttp.request(req)   --log(body, code, hdrs)   if code == 401 and hdrs['www-authenticate'] then     local ht = parse_header(hdrs['www-authenticate'])     log(ht)     if not ht.realm or not ht.nonce then       log("REALM")       return nil, 'missing realm/nonce from response'     end     if ht.qop ~= 'auth' then       log("QOP")       return nil, 'unsupported qop ' .. tostring(ht.qop)     end     if ht.algorithm and ht.algorithm:lower() ~= 'md5' then       log("MD5")       return nil, 'unsupported algo ' .. tostring(ht.algorithm)     end     local nc = '00000001'     local cnonce = string.format('%08x', os.time())     local uri = skturl.build({ path = url.path, query = url.query })     local method = req.method or 'GET'     local response = hash(       hash(user, ht.realm, password),       ht.nonce,       nc,       cnonce,       'auth',       hash(method, uri)     )     req.headers = req.headers or {}     local auth = {       { 'username', user },       { 'realm', ht.realm },       { 'nonce', ht.nonce },       { 'uri', uri },       { 'cnonce', cnonce },       { 'nc', nc, unquote = true },       { 'qop', 'auth' },       { 'algorithm', 'MD5' },       { 'response', response },     }     if ht.opaque then       table.insert(auth, { 'opaque', ht.opaque })     end     req.headers.authorization = make_digest_header(auth)     if not req.headers.cookie and hdrs['set-cookie'] then       -- not really correct but enough for httpbin       local cookie = (hdrs['set-cookie'] .. ';'):match('(.-=.-)[;,]')       if cookie then         req.headers.cookie = '$Version: 0; ' .. cookie .. ';'       end     end     if req.source then       req.source = source     end     body, code, hdrs = skthttp.request(req)   end   return body, code, hdrs end local request = function(url)   local t = type(url)   if t == 'table' then     return _request(table.clone(url))   elseif t == 'string' then     local req = {}     local _, code, headers = _request({ url = url, sink = ltn12.sink.table(req) })     return table.concat(req), code, headers   end end     image, err, hdrs = request(url)   log(image, err, hdrs)   return image,err end
RE: Get Snapshot from Hikvision Camera - by DGrandes - 14.03.2023, 07:57
