Set KNX object's value via HTTP?
Here is a full sample:
You must enable remote services and check the objects for export and use this LUA command to have HTTP communication for older FW use:
require('socket.http') socket.http.TIMEOUT = 5 -- Read from object local reply = socket.http.request('http://remote:remote@192.168.0.10/cgi-bin/scada-remote/request.cgi?m=json&r=grp&fn=getvalue&alias=0/0/8') grp.write('0/0/7', reply) -- Write to object value = grp.getvalue('0/0/7') local reply = socket.http.request('http://remote:remoter@192.168.0.10/cgi-bin/scada-remote/request.cgi?m=json&r=grp&fn=write&alias=0/0/8&value=' .. value .. '')
See for all possible syntax this URL: http://www.openrb.com/docs/remote.htm
For new (and BETA) FW use:
require('socket.http') socket.http.TIMEOUT = 5 -- Read from object local reply = socket.http.request('http://remote:remote@192.168.0.10/scada-remote?m=json&r=grp&fn=getvalue&alias=0/0/8') grp.write('0/0/7', reply) -- Write to object value = grp.getvalue('0/0/7') local reply = socket.http.request('http://remote:remote@192.168.0.10/scada-remote?m=json&r=grp&fn=write&alias=0/0/8&value=' .. value .. '')
See for all possible syntax this URL: http://www.openrb.com/docs/remote-new.htm
I strongly recommend to change the default remote password..
Set KNX object's value via HTTP? - by Thomas - 10.01.2017, 18:25
RE: Set KNX object's value via HTTP? - by Erwin van der Zwart - 11.01.2017, 13:47
