Export objects between neighbours (two spaceLynks)
(19.05.2023, 06:35)admin Wrote: You can run Wireshark on the same network using ip.addr==224.0.23.12 filter to check KNX multicast traffic.
Yes, this could be an option.
Thank you
(19.05.2023, 07:34)Daniel Wrote: You can take a switch, connect both SLs together and then show to IT that it works and it doesn't on IT network.
It could be complicated because SLs are located in different buildings and disconnecting them from the knx network would not be desirable at the moment.
But thanks for the idea
RE: Export objects between neighbours (two spaceLynks) - by Krists - 19.05.2023, 09:49
