grp.write not on KNX TP
I am using the grp.write command in a script to update a boolean.
In the script i use grp.write('1/1/2', true, dt.bool)
The script is triggered by a change in value (another groupaddres) and the script is being triggered (added some log-commands to see what is happening).
The grp.write-command is being executed but is not visible on the groupmonitor (ETS through LM) and nothing happens.
When changing the boolean-value in de objects-tab of the LM it is being send to KNX-TP and shows up in the ETS groupmonitor.
I am not using any filtering on the LM (IP-TP or TP-IP).
Any idea what can cause this? (probably something stupid i guess)
Thanks,
Bart
grp.write not on KNX TP - by bmodeco - 30.01.2017, 12:47
RE: grp.write not on KNX TP - by admin - 30.01.2017, 12:58
RE: grp.write not on KNX TP - by bmodeco - 30.01.2017, 13:07
RE: grp.write not on KNX TP - by bmodeco - 30.01.2017, 19:50
