Use Apple Airtag instead of Rfid tag
(20.09.2023, 15:03)Novodk Wrote:
(20.09.2023, 12:51)admin Wrote: You need to create a resident script that executes ow.list() every second or so. Then you can perform required action when a device with a given ID is present or not.
A bit out of my comfort zone Smile
Do you have any example code, in that direction to get me started?
Hello Novodk.
This is resident script for you.
require('ow') function findDifferences(list, prev_list)   local new_ids = {}   local removed_ids = {}   -- Check for new IDs   if list then     for id, _ in pairs(list) do       if not prev_list or not prev_list[id] then         table.insert(new_ids, id)       end     end   end   -- Check for removed IDs   if prev_list then     for id, _ in pairs(prev_list) do       if not list[id] then         table.insert(removed_ids, id)       end     end   end   return new_ids, removed_ids end list = ow.list() local new_ids, removed_ids = findDifferences(list, prev_list) if #new_ids > 0 then   log("New IDs:")   for _, id in ipairs(new_ids) do     log(id, list[id])   end end if #removed_ids > 0 then   log("Removed IDs:")   for _, id in ipairs(removed_ids) do     log(id, prev_list[id])   end end prev_list = list
RE: Use Apple Airtag instead of Rfid tag - by RomansP - 22.09.2023, 06:31
