email setting
#21
(09.05.2024, 10:36)admin Wrote: What you are getting is not an error but a normal result: first return value is 1 = ok, second is nil = no error.
Thanks. I'm not receiving the email though. See settings below. For the 'from' and 'user' field I'm using the same email adres together with the correct password, verified on "https://outlook.office.com/"
-- send an e-mail function mail(to, subject, message)   -- make sure these settings are correct   local settings = {     -- "from" field, only e-mail must be specified here     from = 'xxxxxxxxxxxxxxxxxxxxxx',     -- smtp username     user = 'xxxxxxxxxxxxxxxxxxxxxx',     -- smtp password     password = ' xxxxxxxxxxxxxxxxxxxxxx',     -- smtp server smtp-mail.outlook.com / smtp.office365.com     server = 'smtp.office365.com',     -- smtp server port     port = 587,      -- enable tls     secure = 'ttlsv1_3',     -- use STARTTLS mode     starttls = true,   }
When using the following log code I'm getting the message below.
res, err = mail(to, subject, message) if not res then   log(err) end
* string: 535 5.7.139 Authentication unsuccessful, the request did not meet the criteria to be authenticated successfully. Contact your administrator. [LO4P123CA0481.GBRP123.PROD.OUTLOOK.COM 2024-05-09T10:33:51.352Z 08DC6E1D1ACB6079]
Is there any documentation with common tested SMTP servers?
Thanks in advance,
Niels
email setting - by gkentsis - 10.10.2017, 12:00
RE: email setting - by admin - 10.10.2017, 12:24
RE: email setting - by gkentsis - 10.10.2017, 19:16
RE: email setting - by admin - 11.10.2017, 07:59
RE: email setting - by gkentsis - 11.10.2017, 08:51
RE: email setting - by admin - 11.10.2017, 10:27
RE: email setting - by gkentsis - 13.10.2017, 08:12
RE: email setting - by admin - 13.10.2017, 08:45
RE: email setting - by gkentsis - 13.10.2017, 09:06
RE: email setting - by admin - 13.10.2017, 10:02
RE: email setting - by Mrinj - 17.11.2017, 18:43
RE: email setting - by Mrinj - 18.11.2017, 11:45
RE: email setting - by Clémentine - 21.11.2017, 14:36
RE: email setting - by admin - 22.11.2017, 13:00
RE: email setting - by joaodaniel.pereira - 27.03.2024, 09:27
RE: email setting - by admin - 27.03.2024, 09:29
RE: email setting - by joaodaniel.pereira - 27.03.2024, 09:47
RE: email setting - by Supersoon - 09.05.2024, 10:34
RE: email setting - by Daniel - 27.03.2024, 09:50
RE: email setting - by admin - 09.05.2024, 10:36
RE: email setting - by Supersoon - 09.05.2024, 10:51
RE: email setting - by admin - 09.05.2024, 10:55
RE: email setting - by Supersoon - 24.05.2024, 18:55
