19.06.2024, 10:54
(18.06.2024, 12:16)admin Wrote: Try this:
Code:nameparam = dbcon:escape('NameX') valueparam = 1000 dbcon:execute("INSERT INTO test (name, value) VALUES ('" .. nameparam .. "', " .. valueparam .. ")")
Hi again, I'm sorry for bothering again, but I dont understand how the " and single ' works formating the text.
I need to add more text fields, and I tried to copy or understand the format but the query responds with:
string: LuaSQL: error executing query. MySQL: You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'kWh Calor', kike', 1000)
and the script:
require('luasql.mysql')
require('json')
http = require('socket.http')
env = luasql.mysql()
dbcon, err = env:connect('knx', 'root','123123', '192.168.6.19', '3306')
log(dbcon, err)
dbcon:execute('SET NAMES utf8')
instalacion_param = dbcon:escape('Building_1')
medida_param = dbcon:escape('P1_2A kWh Calor')
usuario_param = dbcon:escape('kike')
valor_param = 1000
log(dbcon:execute("INSERT INTO test2 (instalacion, medida, usuario, valor) VALUES ('" .. instalacion_param .. "', " .. medida_param .. "', " .. usuario_param .. "', " .. valor_param .. ")"))
What's the difference beetween " and ' dealing with test format in this case? Is there any manual or tip abouts this issue?
Thanks in advance!!
