How to run a scheduled event at Solar Noon?
revised script
--[[ Warning: database functions are subject to change with firmware updates. ]]-- -- Update the start time for any solarNoon scheduler events. local namePrefix = 'solarNoon%' local maxOffsetHours = 8    -- avoid 24hr boundaries local namePattern = "^solarNoon%s*([+-])%s*(0[0-"..maxOffsetHours.."])([0-5]%d)%D*" local typeSpecificTime = '' for _, evt in ipairs(db:getall('SELECT * FROM scheduler_events WHERE name LIKE ?', namePrefix)) do   if evt then     if (type(evt.start_hour) == "number") and (evt.start_hour % 1 == 0) and (type(evt.start_min) == "number") and (evt.start_min % 1 == 0) and (type(evt.type) == 'string') then           local _, _, plusMinus, offsetHour, offsetMin = string.find(evt.name, namePattern)       if plusMinus and offsetHour and offsetMin and (evt.type == typeSpecificTime) then         local sunrise, sunset = rscalc(latitudeMel, longitudeMel)         local solarNoon = math.floor(((sunset + sunrise) / 2) + 0.5) -- approximation         local offsetMinutes = (offsetHour * 60) + offsetMin         local eventMinutes         if plusMinus == '+' then           eventMinutes = solarNoon + offsetMinutes         else           eventMinutes = solarNoon - offsetMinutes         end         local eventStartHour = math.floor(eventMinutes / 60)         local eventStartMin = math.floor(eventMinutes % 60)         if (evt.start_hour ~= eventStartHour) or (evt.start_min ~= eventStartMin) then           db:update('scheduler_events', {             start_hour = eventStartHour,             start_min = eventStartMin           }, { id = evt.id })           io.writefile('/tmp/lm-scheduler-clear', '')         end       else         log("Error. '"..evt.name.."' event name must begin with 'solarNoon[+-]HHMM' where max HH = 0"..maxOffsetHours..", and event setting 'Run at:' must be 'Specific time'")       end           else       log("Error. Firmware change, check evt.start_hour and evt.start_min are integers, and evt.type is a string.", evt)     end   end end
RE: How to run a scheduled event at Solar Noon? - by sgraystar - 03.09.2024, 00:19
