Control Nefit boiler
I like to control a Nefit boiler that has an EMS protocol. Its not possible to control it directly so i inserted an EMS-ESP into my system.
Now i can get data from my system with this script
--[[ Nefit heat pump ems bus https://bbqkees-electronics.nl/wiki/gateway/restful-api.html https://docs.emsesp.org/Commands/ ems-esp/boiler                                        {"cmd":"heatingactivated", "data":"on"}        turn on heatingactivated in boiler ems-esp/boiler/heatingactivated        {"data":"on"}                                                            turn on heatingactivated in boiler (equivalent to command above) ems-esp/boiler                                        {"cmd":"dhw.disinfecting", "data":"on"}        turn on DHW disinfecting in boiler --]] https = require('ssl.https') json = require('json') ltn12 = require('ltn12') iDebug = true devIp = '192.168.x.xx' -- ems-esp.local devUrl = 'http://'..devIp..'/api/' function getData(iFunction)   if iDebug then log(devUrl..iFunction) end   res, code = https.request({       url = devUrl..iFunction,       method = 'GET'   })   if iDebug then       log(code, res)   end   return code, res end function setData(iFunction, iData)   if iDebug then log(devUrl..iFunction) end   res, code = https.request({       url = devUrl..iFunction,       method = 'POST',       headers = {["content-type"] = "application/json"},       data = iData       })   if iDebug then       log(code, res)   end   return code, res end -- get system info --getData('system') -- get boiler info - GET outputs current EMS device information in verbose --getData('boiler/info') -- get boiler values - GET outputs current EMS device information in short format --getData('boiler/values') -- get boiler - GET    same as values above --getData('boiler') -- get boiler commands - GET    lists the available command entities to call --getData('boiler/commands') -- get boiler entities -     GET    lists all enabled entities --getData('boiler/entities') -- get boiler dhw info --getData('boiler/dhw/info') -- get boiler entity heatingactive --getData('boiler/heatingactive') -- thermostaat streeftemperatuur --getData('thermostat/seltemp') -- dhw Laden --getData('thermostat/dhw/charge') setData('thermostat/dhw/charge', '{"value": true}') --curl -X POST http:///api/system/dhw/charge -H "Content-Type: application/json" -d '{"value": true}'
I also like to control the data with the setData function (last line). But i received an error 400. Whats wrong with my code?
Documentation can be found here: https://docs.emsesp.org/Commands/
Control Nefit boiler - by gjniewenhuijse - 26.09.2025, 12:53
RE: Control Nefit boiler - by admin - 26.09.2025, 12:58
RE: Control Nefit boiler - by gjniewenhuijse - 26.09.2025, 13:07
RE: Control Nefit boiler - by admin - 26.09.2025, 13:13
RE: Control Nefit boiler - by gjniewenhuijse - 26.09.2025, 13:20
RE: Control Nefit boiler - by admin - 26.09.2025, 13:27
RE: Control Nefit boiler - by gjniewenhuijse - 26.09.2025, 13:33
RE: Control Nefit boiler - by admin - 26.09.2025, 13:39
RE: Control Nefit boiler - by gjniewenhuijse - 26.09.2025, 13:49
RE: Control Nefit boiler - by admin - 26.09.2025, 14:05
RE: Control Nefit boiler - by gjniewenhuijse - 08.10.2025, 09:32
RE: Control Nefit boiler - by maxmp - 26.09.2025, 21:00
RE: Control Nefit boiler - by gjniewenhuijse - 29.09.2025, 08:58
RE: Control Nefit boiler - by maxmp - 06.10.2025, 06:52
RE: Control Nefit boiler - by gjniewenhuijse - 07.10.2025, 09:27
RE: Control Nefit boiler - by admin - 08.10.2025, 09:39
RE: Control Nefit boiler - by gjniewenhuijse - 08.10.2025, 09:53
