Syslog differences between Resident and Event Scripts
I have the exact same Syslog set up in my Resident and Event Scripts - the Resident Scripts Syslog works, however the Event scripts doesnt
The syslog set up that works in Resident is
local socket = require("socket")
-- SYSLOG CONFIG
local SYSLOG_HOST = "192.168.1.51"
local SYSLOG_PORT = 1514
local HOSTNAME = "logicmachine"
local APPNAME  = "solar-master"
local LOG_INTERVAL = 60  -- seconds
-- PERSISTENT UDP SOCKET
storage.syslog_socket = storage.syslog_socket or socket.udp()
local udp = storage.syslog_socket
udp:settimeout(0)
-- RFC5424 TIMESTAMP
local function rfc5424_time()
  local now = os.time()
  local utc = os.time(os.date("!*t", now))
  local offset = os.difftime(now, utc)
  local sign = "+"
  if offset < 0 then sign = "-" end
  offset = math.abs(offset)
  local hours = math.floor(offset / 3600)
  local mins  = math.floor((offset % 3600) / 60)
  return os.date("%Y-%m-%dT%H:%M:%S") ..
        string.format("%s%02d:%02d", sign, hours, mins)
-- SYSLOG SENDER
local function slog(fields)
  local timestamp = rfc5424_time()
  local msg = "<14>1 "..timestamp.." "..HOSTNAME.." "..APPNAME.." - - - "..fields
  udp:sendto(msg, SYSLOG_HOST, SYSLOG_PORT)
What needs to change for an Event Script to behave the same way and allow for logging to an external syslog server?
Syslog differences between Resident and Event Scripts - by BarryFromBondi - 12.03.2026, 20:59
