Syslog differences between Resident and Event Scripts
Sharing socket between scripts is not possible. You can simply create a new socket for each slog() call.
Add the following code to Common functions to make slog() function available for all scripts.
local function rfc5424_time()   local now = os.time()   local utc = os.time(os.date("!*t", now))   local offset = os.difftime(now, utc)   local sign = "+"   if offset < 0 then sign = "-" end   offset = math.abs(offset)   local hours = math.floor(offset / 3600)   local mins  = math.floor((offset % 3600) / 60)   return os.date("%Y-%m-%dT%H:%M:%S") ..         string.format("%s%02d:%02d", sign, hours, mins) end function slog(fields)   local SYSLOG_HOST = "192.168.0.2"   local SYSLOG_PORT = 1514   local HOSTNAME = "logicmachine"   local APPNAME  = "solar-master"   local timestamp = rfc5424_time()   local msg = "<14>1 "..timestamp.." "..HOSTNAME.." "..APPNAME.." - - - "..fields   local sock = require('socket').udp()   sock:sendto(msg, SYSLOG_HOST, SYSLOG_PORT)   sock:close() end
RE: Syslog differences between Resident and Event Scripts - by admin - 13.03.2026, 07:49
