10.11.2026, 08:21
Nov 10 08:14:31 LAMBO-CAB4 daemon.info avahi-daemon[1322]: Registering new address record for 10.147.20.25 on ztppiynnew.IPv4.
Nov 10 08:14:31 LAMBO-CAB4 daemon.info avahi-daemon[1322]: New relevant interface ztppiynnew.IPv4 for mDNS.
Nov 10 08:14:31 LAMBO-CAB4 daemon.info avahi-daemon[1322]: Joining mDNS multicast group on interface ztppiynnew.IPv4 with address 10.147.20.25.
Nov 10 08:14:16 LAMBO-CAB4 daemon.notice pppd[1419]: secondary DNS address 10.128.28.16
Nov 10 08:14:16 LAMBO-CAB4 daemon.notice pppd[1419]: primary DNS address 10.133.106.110
Nov 10 08:14:16 LAMBO-CAB4 daemon.notice pppd[1419]: remote IP address 10.64.64.64
Nov 10 08:14:16 LAMBO-CAB4 daemon.notice pppd[1419]: local IP address 100.106.52.131
Nov 10 08:14:16 LAMBO-CAB4 daemon.notice pppd[1419]: replacing old default route to eth0 [192.168.0.1]
Nov 10 08:14:16 LAMBO-CAB4 daemon.info avahi-daemon[1322]: Registering new address record for 100.106.52.131 on ppp0.IPv4.
Nov 10 08:14:16 LAMBO-CAB4 daemon.info avahi-daemon[1322]: New relevant interface ppp0.IPv4 for mDNS.
Nov 10 08:14:16 LAMBO-CAB4 daemon.info avahi-daemon[1322]: Joining mDNS multicast group on interface ppp0.IPv4 with address 100.106.52.131.
Nov 10 08:14:16 LAMBO-CAB4 daemon.warn pppd[1419]: Could not determine remote IP address: defaulting to 10.64.64.64
Nov 10 08:14:14 LAMBO-CAB4 daemon.notice pppd[1419]: Connect: ppp0 <--> /dev/ttyUSB3
Nov 10 08:14:14 LAMBO-CAB4 daemon.info pppd[1419]: Using interface ppp0
Nov 10 08:14:14 LAMBO-CAB4 daemon.info pppd[1419]: Serial connection established.
Nov 10 08:14:12 LAMBO-CAB4 daemon.notice pppd[1419]: pppd 2.4.9 started by root, uid 0
Nov 10 08:14:09 LAMBO-CAB4 daemon.info pppd[1417]: Exit.
Nov 10 08:14:08 LAMBO-CAB4 daemon.err pppd[1417]: Connect script failed
Nov 10 08:14:05 LAMBO-CAB4 daemon.notice pppd[1417]: pppd 2.4.9 started by root, uid 0
Nov 10 08:14:01 LAMBO-CAB4 kern.info kernel: [ 10.757104] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB4
Nov 10 08:14:01 LAMBO-CAB4 kern.info kernel: [ 10.756522] option 2-1:1.4: GSM modem (1-port) converter detected
Nov 10 08:14:01 LAMBO-CAB4 kern.info kernel: [ 10.755492] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB3
Nov 10 08:14:01 LAMBO-CAB4 kern.info kernel: [ 10.754884] option 2-1:1.3: GSM modem (1-port) converter detected
Nov 10 08:14:01 LAMBO-CAB4 kern.info kernel: [ 10.747381] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB2
Nov 10 08:14:01 LAMBO-CAB4 kern.info kernel: [ 10.745184] option 2-1:1.2: GSM modem (1-port) converter detected
Nov 10 08:14:01 LAMBO-CAB4 kern.info kernel: [ 10.744191] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB1
Nov 10 08:14:01 LAMBO-CAB4 kern.info kernel: [ 10.743594] option 2-1:1.1: GSM modem (1-port) converter detected
Nov 10 08:14:01 LAMBO-CAB4 kern.info kernel: [ 10.741249] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB0
Nov 10 08:14:01 LAMBO-CAB4 kern.info kernel: [ 10.740627] option 2-1:1.0: GSM modem (1-port) converter detected
Nov 10 08:14:01 LAMBO-CAB4 kern.info kernel: [ 10.737678] usb 2-1: SerialNumber: 0123456789ABCDEF
Nov 10 08:14:01 LAMBO-CAB4 kern.info kernel: [ 10.737666] usb 2-1: Manufacturer: SimTech, Incorporated
Nov 10 08:14:01 LAMBO-CAB4 kern.info kernel: [ 10.737654] usb 2-1: Product: SimTech, Incorporated
Nov 10 08:14:01 LAMBO-CAB4 kern.info kernel: [ 10.737642] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Nov 10 08:14:01 LAMBO-CAB4 kern.info kernel: [ 10.737612] usb 2-1: New USB device found, idVendor=1e0e, idProduct=9001, bcdDevice= 3.18
Nov 10 08:14:01 LAMBO-CAB4 kern.info kernel: [ 10.569367] usb 2-1: new high-speed USB device number 4 using ci_hdrc
Nov 10 08:13:59 LAMBO-CAB4 daemon.info avahi-daemon[1322]: Registering HINFO record with values 'ARMV7L'/'LINUX'.
Nov 10 08:13:59 LAMBO-CAB4 daemon.info avahi-daemon[1322]: Server startup complete. Host name is LAMBO-CAB4.local. Local service cookie is 716297664.
Nov 10 08:13:59 LAMBO-CAB4 daemon.info avahi-daemon[1322]: Registering new address record for 192.168.0.10 on eth0.IPv4.
Nov 10 08:13:59 LAMBO-CAB4 daemon.info avahi-daemon[1322]: Registering new address record for fe80::88cd:18ff:feab:4b4d on ztppiynnew.*.
Nov 10 08:13:59 LAMBO-CAB4 daemon.info avahi-daemon[1322]: Network interface enumeration completed.
Nov 10 08:13:59 LAMBO-CAB4 daemon.info avahi-daemon[1322]: New relevant interface eth0.IPv4 for mDNS.
Nov 10 08:13:59 LAMBO-CAB4 daemon.info avahi-daemon[1322]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.0.10.
Nov 10 08:13:59 LAMBO-CAB4 daemon.info avahi-daemon[1322]: Loading service file /etc/avahi/services/lm.service.
Nov 10 08:13:59 LAMBO-CAB4 daemon.info avahi-daemon[1322]: Loading service file /etc/avahi/services/http.service.
Nov 10 08:13:59 LAMBO-CAB4 daemon.info avahi-daemon[1322]: avahi-daemon 0.8 starting up.
Nov 10 08:13:59 LAMBO-CAB4 daemon.info avahi-daemon[1322]: Successfully dropped root privileges.
Nov 10 08:13:59 LAMBO-CAB4 daemon.info avahi-daemon[1322]: Found user 'nobody' (UID 65534) and group 'nogroup' (GID 65534).
Nov 10 08:13:58 LAMBO-CAB4 user.info sysinit: No packages removed.
Nov 10 08:13:56 LAMBO-CAB4 user.info sysinit: Failed to get init ACK from device: 57 196
Nov 10 08:13:54 LAMBO-CAB4 user.info sysinit: /lib/genohm-scada/storage/db/current.db: OK(10.11.2026, 07:42)admin Wrote: Reboot LM and post what you get in System config > Status > System log.
