Check connected tcp ports
I don't know exactly but this was my subject when I used the storage for such solution:
https://forum.logicmachine.net/showthrea...ight=somfy
In that case I've tried push button to e.g. rotate the slat step by step and Somfy was very slow(~0,6s for sending one command). So when I clicked very fast 3 times then I had a problem also with storage and e.g. Somfy did only 2 steps. I've tested this on LM4 on old processor so I think it could also had some influence. When I've used UDP server for this the problem gone and CPU usage go to minimum level from very high.
Check connected tcp ports - by buuuudzik - 22.06.2017, 12:24
RE: Check connected tcp ports - by admin - 22.06.2017, 12:32
RE: Check connected tcp ports - by mlaudren - 23.06.2017, 12:27
RE: Check connected tcp ports - by buuuudzik - 23.06.2017, 14:12
RE: Check connected tcp ports - by mlaudren - 23.06.2017, 14:37
RE: Check connected tcp ports - by buuuudzik - 23.06.2017, 14:51
RE: Check connected tcp ports - by admin - 23.06.2017, 17:29
RE: Check connected tcp ports - by rocfusion - 25.06.2017, 21:50
