ELK M1 Alarm panel
Hi Admin,
Thank you,  the checksum function works.  I am trying to do the reverse and verify the message received has a valid checksum
function checksum(str)  local sum = 0  for i = 1, #str do    sum = (sum + string.byte(str,i)) % 256  end  x = 256-sum  return string.format('%02X', 256 - sum) end function reversechk(str, cksum)  local sum = tonumber(cksum,16)  log(sum)  for i=1, #str do    sum= (sum + string.byte(str,i))  end  return string.format('%02X', sum) end local message= '16XK403923611081711000' local chksum = checksum(message) log(chksum) -- chksum is 67 -- so the total message is '16XK40392361108171100067' local isok = reversechk(message,chksum) log(isok)
The reversechk function does not return a 0,  what am doing wrong?  I have the reverse calculation in C code,  maybe you can understand what they doing?
Calculate checksum on received and transmitted ASCII string Example C code program //INT8U is an 8 bit unsigned integer. INT8U itAscRecBuf[82]; //ASCII receive character buffer INT8U AscHexToBin(INT8U, INT8U *); //ASCII hex to binary conversion INT8U AsciiToHex( INT8U); //Ascii to Hex conversion //Calculate checksum on a received ASCII string, return checksum value. //It should equal 0 if good. INT8U CalcCheckSum(void) {     INT8U i,length, cc;     length = AscHexToBin(2, &itAscRecBuf[0]);     //get length value, first two characters          cc = AscHexToBin(2, &itAscRecBuf[length]); //get checksum value at end of string.     for (i=0;i<length ;i++ )         {             cc += itAscRecBuf[i]; //get string value and add it to checksum         }         return(cc);         //good checksum should equal 0 }     //ascii hex to binary, width 1 or 2     INT8U AscHexToBin(INT8U Width, INT8U * DataPtr) //         {             INT8U aVal; // accumulated value             aVal = AsciiToHex(*DataPtr);             DataPtr++;             if (Width == 2)    //two digits wide, else 1 digit wide                 {                     aVal = aVal << 4;                     aVal += AsciiToHex(*DataPtr);                 }             return(aVal);          }     //Ascii to Hex conversion     INT8U AsciiToHex( INT8U Value )         {             switch ( Value )                 {                     case 'A': return( 10 );                     case 'B': return( 11 );                     case 'C': return( 12 );                     case 'D': return( 13 );                     case 'E': return( 14 );                     case 'F': return( 15 );                     default: return( Value - 0x30 );                 }         }
Thanks,
Roger
ELK M1 Alarm panel - by rocfusion - 07.08.2017, 17:04
RE: ELK M1 Alarm panel - by admin - 08.08.2017, 08:50
RE: ELK M1 Alarm panel - by rocfusion - 12.08.2017, 23:21
RE: ELK M1 Alarm panel - by admin - 14.08.2017, 06:13
RE: ELK M1 Alarm panel - by rocfusion - 14.08.2017, 17:14
RE: ELK M1 Alarm panel - by admin - 17.08.2017, 06:30
RE: ELK M1 Alarm panel - by rocfusion - 17.08.2017, 07:07
RE: ELK M1 Alarm panel - by rocfusion - 19.08.2017, 23:32
RE: ELK M1 Alarm panel - by rocfusion - 22.08.2017, 06:31
RE: ELK M1 Alarm panel - by admin - 22.08.2017, 06:52
