22.08.2017, 06:31
(19.08.2017, 23:32)rocfusion Wrote: Hi Admin,
Ok so with a slight modification its now working, see the revised code below. Question in terms of error handling for the connection will this be sufficient for this client script to reconnect if for whatever reason the connection is lost?
Thanks,
Roger
Code:if not skt then skt = socket.tcp() skt:settimeout(5) skt:connect('192.168.0.11', 2601) skt, err = ssl.wrap(skt,'tlsv1') if not err then skt:dohandshake() skt = copas.wrap(skt) copas.addthread(function() while true do local resp,err = copas.receive(skt) -- if theres no connection start a new connection if not resp or err ~=nil then alert("[elk-client] Receive error: %s", err) copas.removeserver(skt) skt = nil break end if(string.find(resp,'^16XK')==nil)then local fd,prtd = pcall(parse,resp) if(fd==false)then alert("[elk-client] Error with parsemsg %s ",prtd) end else alert('[elk-client] time message: %s', resp) end end end) else alert("[elk-client] connection error: %s", err) skt = nil return end end
Hi Admin, is this ok?
Thx
Roger
