Memory Usage
Sad
Hello!
I'm have a problem with the memory load/usage on my LM Ambient.
Whenever i reset the LM Ambient, the Memory load is around 15-19%, but each day it increases by 2-4%.
A few days ago the load was at 90%, so I tried installing the newest firmware, but the same thing keeps happening.
Is there a possibility that any of my scripts could be causing this? I'm relatively new to LUA so it would be fair to assume that this might be of my own doing!
Some additional info
I have attached my trend logs.
No object logs are active.
I'm only using Z-Wave products, about 40 of them are connected to my LM.
A function/user.library that is called every 1 second for 4 different light zones in the same resident script
function auto_lysstyring(auto_on, nattsenking, sensor, light_type, light_control, dim_value_day, dim_value_night, off_time)    if grp.getvalue(auto_on) == true then       offtime = off_time -- Tid i minutter for å slå av lys etter siste bevegelse     dim_day = dim_value_day -- Dimmeverdi på dagtid     dim_night = dim_value_night -- Dimmeverdi etter nattsenking     nattsenk = grp.getvalue(nattsenking) -- Henter nattsenk status true/false     mov_sensor = grp.getvalue(sensor) -- Sjekker bevegelse i rommet  light_type_check = light_type  light_control_check = grp.getvalue(light_control)  obj_find = grp.find(sensor)     delta = os.time() - obj_find.updatetime        if light_type_check == 1 then -- Light type 1 for dimming      if mov_sensor == true then        if light_control_check < 10 then          if nattsenk == true then            grp.update(light_control, dim_night)            elseif nattsenk == false then            grp.update(light_control, dim_day)            end          end      end            if mov_sensor == false and delta >= offtime * 60 then        if light_control_check > 0 then          grp.update(light_control, 0)          end      end    end        if light_type_check == 0 then -- Light type 1 for av/på      if mov_sensor == true then        if light_control_check ==false then          grp.update(light_control, true)          end        end            if mov_sensor == false and delta >= offtime * 60 then        if light_control_check == true then          grp.update(light_control, false)        end              end          end      else  end   end
A resident script that runs every 5 seconds
obj_find = grp.find('1/1/35') -- Gesture sensor value delta = os.time() - obj_find.updatetime if delta >= 5 and delta < 9.99 then  gesture = grp.getvalue('1/1/35') -- Green light, ECO Mode. Sets thermostats to ECO and turns off all lights if gesture == 1 then    -- upate HVAC MODE to ECO  grp.update('1/1/66', 3)    -- Turn off all lights  bit_objects = grp.tag('ALT_AV_BIT')     byte_objects = grp.tag('ALT_AV_BYTE')  for index, value in ipairs(bit_objects) do      grp.update(value.address, false)     end     for index, value in ipairs(byte_objects) do      grp.update(value.address, 0)     end   end -- Orange light, Comfort mode. Sets thermostats to Comfort, lights are untouched. if gesture == 2 then  -- upate HVAC MODE to Comfort  grp.update('1/1/66', 1) end -- Black Light, turns off all lights. if gesture == 3 then  -- Turn off all lights  bit_objects = grp.tag('ALT_AV_BIT')     byte_objects = grp.tag('ALT_AV_BYTE')  for index, value in ipairs(bit_objects) do      grp.update(value.address, false)     end     for index, value in ipairs(byte_objects) do      grp.update(value.address, 0)     end   end -- yellow Light, turns on all lights. if gesture == 4 then  -- Turn off all lights  bit_objects = grp.tag('ALT_AV_BIT')     byte_objects = grp.tag('ALT_AV_BYTE')  for index, value in ipairs(bit_objects) do    grp.update(value.address, true)     end     for index, value in ipairs(byte_objects) do      grp.update(value.address, 90)     end   end end
A resident script that runs every 60 seconds
-- get an array of objects tagged 'tag name' myobjects = grp.tag('Battery') batteryfails = 0 -- arraytable = { 'a', 'b', 'c' } for index, value in ipairs(myobjects) do  batterycheck = grp.getvalue(value.address)  if batterycheck < 10 then --rapporterer alle batterier under 10%    batteryfails = batteryfails + 1 end     end if batteryfails > 0 then        grp.update('1/1/105', batteryfails)  grp.update('1/1/104', true) elseif batteryfails == 0 and grp.getvalue('1/1/104') == true then  grp.update('1/1/105', batteryfails)  grp.update('1/1/104', false) end
Memory Usage - by Krstfr2k - 12.09.2017, 06:49
RE: Memory Usage - by admin - 12.09.2017, 09:00
RE: Memory Usage - by Krstfr2k - 12.09.2017, 09:19
RE: Memory Usage - by admin - 12.09.2017, 10:53
RE: Memory Usage - by Krstfr2k - 12.09.2017, 11:37
RE: Memory Usage - by admin - 12.09.2017, 11:50
