15.11.2017, 12:53
(12.11.2017, 11:12)Erwin van der Zwart Wrote: Hi,
When the objects are asigned to a group address inside the ETS, then the read flag must also been set on the object to be able to read the object value from the (any) controller.
When all of the above is correct you can execute a grp.read(address) to request the current value from the object(s).
This has not been done in my house. I have not yet received any ets-file from my electrician. On the other hand I have found out what was wrong with the switch. It happened that the location where the switch is placed is hit by direct sunlight, meaning that the measured temperature is increased until the switch resets itself and the default temp is set. Looking into this now.
