Modbus TCP slave example
️ This script is outdated use this script instead: https://forum.logicmachine.net/showthread.php?tid=4288
Simple example of how to implement Modbus TCP slave via a resident script (sleep time = 0). It only supports binary objects as coils and 1-byte / 2-byte integer objects as registers. Number of coils and registers is not limited, object mapping can be set by filling coils, registers and regdt tables.
if not mb then   require('genohm-scada.eibdgm')   require('luamodbus')   -- list of coil mapping, starting from 0   coils = { '1/1/1', '1/1/2' }   -- list of register mapping, starting from 0   registers = { '2/2/2', '3/3/3' }   -- list of register data types, element count must match registers table   regdt = { dt.int8, dt.uint16 }   -- knx group write callback   function knxgroupwrite(event)     local value     -- try to find matching coil     for id, addr in ipairs(coils) do       if event.dst == addr then         value = knxdatatype.decode(event.datahex, dt.bool)         mb:setcoils(id - 1, value)       end     end     -- try to find matching register     for id, addr in ipairs(registers) do       if event.dst == addr then         value = knxdatatype.decode(event.datahex, regdt[ id ])         mb:setregisters(id - 1, value)       end     end   end   -- coil write callback   function mbwritecoils(coil, value)     local addr = coils[ coil + 1 ]     if addr then       grp.write(addr, value, dt.bool)     end   end   -- register write callback   function mbwriteregisters(register, value)     local addr = registers[ register + 1 ]     if addr then       grp.write(addr, value, regdt[ register + 1])     end   end   -- knx group monitor, handles group writes   knxclient = eibdgm:new({ timeout = 0.1 })   knxclient:sethandler('groupwrite', knxgroupwrite)   -- modbus slave, listen on all interfaces and default port 502   mb = luamodbus.tcp()   mb:open('0.0.0.0', 502)   -- setting slave id is optional   -- mb:setslave(1)   mb:setreceivetimeout(0.1)   mb:setmapping(#coils, 0, #registers, 0)   -- init coils   for id, addr in ipairs(coils) do     value = grp.getvalue(addr)     mb:setcoils(id - 1, value)   end   -- init registers   for id, addr in ipairs(registers) do     value = grp.getvalue(addr)     mb:setregisters(id - 1, value)   end   -- set callbacks for coil and register write   mb:setwritecoilcb(mbwritecoils)   mb:setwriteregistercb(mbwriteregisters) end -- handle modbus and knx mb:handleslave() knxclient:loop(0.1)
Modbus TCP slave example - by admin - 08.01.2016, 08:46
RE: Modbus TCP slave example - by Deniss - 15.01.2016, 08:58
RE: Modbus TCP slave example - by admin - 15.01.2016, 14:39
RE: Modbus TCP slave example - by admin - 18.01.2016, 12:57
RE: Modbus TCP slave example - by automatikas - 02.02.2017, 11:30
RE: Modbus TCP slave example - by admin - 02.02.2017, 12:09
RE: Modbus TCP slave example - by automatikas - 02.02.2017, 13:35
RE: Modbus TCP slave example - by automatikas - 29.03.2017, 10:26
RE: Modbus TCP slave example - by admin - 29.03.2017, 10:37
RE: Modbus TCP slave example - by leondias - 29.03.2017, 10:40
RE: Modbus TCP slave example - by automatikas - 29.03.2017, 10:41
RE: Modbus TCP slave example - by admin - 29.03.2017, 10:55
RE: Modbus TCP slave example - by automatikas - 29.03.2017, 11:15
RE: Modbus TCP slave example - by Deniss - 20.04.2017, 06:47
RE: Modbus TCP slave example - by admin - 20.04.2017, 15:38
RE: Modbus TCP slave example - by duvelken - 02.12.2017, 08:13
RE: Modbus TCP slave example - by admin - 03.12.2017, 09:58
RE: Modbus TCP slave example - by FatMax - 13.12.2018, 14:44
RE: Modbus TCP slave example - by admin - 13.12.2018, 15:23
RE: Modbus TCP slave example - by FatMax - 13.12.2018, 15:53
RE: Modbus TCP slave example - by rw_echo - 16.03.2023, 07:57
RE: Modbus TCP slave example - by admin - 17.03.2023, 10:52
