conection
1) Make sure the filter tables are correct in the IP routers and during testing try with all filters open, after that you can add restricted filter settings.
2) Make sure all KNX routers and SL are in the same network scope like 192.168.0.xxx and that all KNX multicast addresses are the same and correct (default = 224.0.23.12).
3) Make sure KNX IP Features is enabled in the SL's KNX settings.
4) Make sure all routers have correct zone / line address like 1.0.0, 1.1.0, 1.2.0, 1.3.0.
If you follow steps above it should work..
conection - by balatis - 03.05.2018, 11:49
RE: conection - by Erwin van der Zwart - 03.05.2018, 17:36
RE: conection - by balatis - 04.05.2018, 10:47
RE: conection - by Erwin van der Zwart - 04.05.2018, 12:06
RE: conection - by balatis - 06.05.2018, 19:21
RE: conection - by Erwin van der Zwart - 06.05.2018, 20:31
RE: conection - by balatis - 21.05.2018, 09:47
RE: conection - by Daniel - 21.05.2018, 10:14
RE: conection - by balatis - 21.05.2018, 10:34
RE: conection - by admin - 21.05.2018, 10:57
RE: conection - by Daniel - 21.05.2018, 10:58
RE: conection - by balatis - 21.05.2018, 11:26
RE: conection - by Daniel - 21.05.2018, 11:40
RE: conection - by balatis - 21.05.2018, 11:46
