Create Modbus client via script
The new FW requires a extra parameter 'timeout' that old FW didn't use, and also new browsers are blocking credentials in URL so i changed the script in a new methode for web requests.
Thanks to Admin for that (:
Here is the new script:
-- Batch adding modbus devices v1.1 - Created by Erwin van der Zwart - Schneider Electric Netherlands ----------- -- For spaceLYnk FW 2.1.1 or higher and Wiser for KNX FW 2.1.1 or higher ---------------------------------------- ----------------------------------------------- Start Parameters ------------------------------------------------ Number_of_devices = 10 Device_name_prefix = "Device" Device_protocol = "tcp" Device_port = 502 Device_ip_range = "192.168.0" Device_ip_start = 1 Device_profile = "iEM-iEM3155" Device_timeout = 3 Device_pollinterval = 5 Device_slave_start = 1 ------------------------------------------------ End Parameters ------------------------------------------------- ------------------------------------ DON'T CHANGE ANYTHING UNDER THIS LINE -------------------------------------- -- Set counters for creation log number_of_devices = 0 number_failed = 0 -- Function to send request (in this case to create a modbus device) function webrequest(mod, act, vars, data)   require('json')   require('dbenv')   local path   vars = vars or {}   function getvar(v)     return vars[ v ]   end   json.data = function()     return data or {}   end   if mod == 'plugin' then     path = 'plugins/' .. act .. '/web.lua'   else     path = 'web/' .. mod .. '/' .. act .. '.lua'   end   return dofile('/lib/genohm-scada/' .. path) end -- Create devices for i = 0, Number_of_devices - 1, 1 do  requestdata = {    id = "",    timeout = "" .. Device_timeout,    pollinterval = "" .. Device_pollinterval,    slave = "" .. Device_slave_start + i,    port = "" .. Device_port,    ip = Device_ip_range .. "." .. Device_ip_start + i,    profile = Device_profile,    name = Device_name_prefix .. " " .. i + 1,    proto = Device_protocol,  }  result = webrequest('plugin', 'modbus', {request = 'device-save'}, requestdata)  -- Calculate results for creation devices log  if result == '{"success":true}' then    number_of_devices = number_of_devices + 1  else    number_failed = number_failed + 1  end end -- Create result log if number_failed == 0 then  log ("Created " .. number_of_devices .. " devices succesfully") else  log ("Created " .. number_of_devices .. " devices succesfully and creation of " .. number_failed .. " devices failed") end -- Disable script when done automaticly script.disable(_SCRIPTNAME)
Create Modbus client via script - by FatMax - 17.02.2017, 11:31
RE: Create Modbus client via script - by AEK - 28.09.2017, 16:04
RE: Create Modbus client via script - by AEK - 29.09.2017, 07:56
RE: Create Modbus client via script - by Erwin van der Zwart - 28.05.2018, 08:16
RE: Create Modbus client via script - by AEK - 02.08.2018, 10:55
