influxdb library
I am sharing a way to send easily object values to influxdb.
Update server and database name before using it.
influx_clim send object with tag "influx_clim"
add "influx_clim()" to a schedule for automatic export
require 'ltn12'
require 'socket.http'
local https = require("ssl.https")
local influxdb_debug = true
local influxdb_server = "https://user:pass@host:8086"
local influxdb_database = "db_name"
local influxdb_buffer
--function used to convert object name (logicmachine) to valid influxdb field key
function influxdb_normalize(name)
 return string.gsub(name,  " ", "_")
--add an entry to be send
function influxdb_add(line_protocol)
 if (influxdb_debug) then
   alert("influxdb_add start")
 if influxdb_buffer then
   influxdb_buffer = influxdb_buffer .. "\n" .. tostring(line_protocol)
   influxdb_buffer =  tostring(line_protocol)
   alert("influxdb_add done")
function influxdb_current()
 return influxdb_buffer
-- send the buffer to influxdb
function influxdb_send()
   alert("influxdb_send start")
 local request_insert_url = influxdb_server .. "/write?db=" .. influxdb_database
--  log(influxdb_buffer)
 local response_body = { }
 local body, code, hdrs, stat = https.request
   url = request_insert_url;
   verify = "none";
   method = "POST";
   headers =
     ["Content-Length"] = #influxdb_buffer;
   source = ltn12.source.string(influxdb_buffer);
   sink = ltn12.sink.table(response_body);
 influxdb_buffer = nil
 if (code ~= 204) then
   alert("influxdb error code:" .. tostring(code))
   alert("influxdb_send http post error")
      alert("influxdb_send done")
--export all objects with tag "influx_clim"
function influx_clim()
 local values=grp.tag("influx_clim")
   alert("influx_cilm start")
 local txtvalues = ""
 for index, id in ipairs(values) do
   -- add separator
   if (#txtvalues>0) then
     txtvalues = txtvalues .. ","
   -- calculate value to be sent
   if (type(id["data"])=="boolean") then
     value=id["data"] and 1 or 0
     value=id["data"]
   -- add key value pair
   txtvalues = txtvalues .. influxdb_normalize(id["name"]) .. "=" .. value
 influxdb_add("clim " .. txtvalues)
 influxdb_send()
 if (debug) then
   alert("influx_cilm end")
(20.10.2018, 21:13)Matt Wrote: I am sharing a way to send easily object values to influxdb.
require 'ltn12'
   verify = "none";
   method = "POST";
   headers =
   -- add separator
     value=id["data"]
 influxdb_send()
 if (debug) then
Hi, I am working on this script but It seems it does not work.
I mean that I use the script above in a library and in a scheduled script which runs everyminute I wrote as followed:
objs = grp.tag('influx_clim')
require ('user.influx')
The problem is that I expect some alert message (correct or incorrect) but nothing happened. How can sort it out?
In the schedule, you only need to have:
influx_clim()
(04.11.2020, 12:42)Matt Wrote: In the schedule, you only need to have:
influx_clim()
Sorry but I forgot to leave the feedback.
Everything works fine.
