Resident script pump circulation
#21
(10.03.2018, 17:16)buuuudzik Wrote:
(10.03.2018, 17:14)Domoticatorino Wrote: It is a Schneider HL 2.0.1
I mean updated version of above scriptWink I've adjusted it to be more universal, added new variables:
valveStatesTag = 'circulation_pump'
pumpGA = '1/1/10'
openingValveTime = 300 -- time for fully open the valve (maximum time for next calculation)
minInterval = 30 -- minimum offset for next calculation
opened, firstTimestamp = false, 0
valveStates = grp.tag(valveStatesTag)
for v = 1, #valveStates, 1 do
 valveState = valveStates[v]
 if valveState.value then
   opened = true
   if firstTimestamp > 0 then
       if firstTimestamp > valveState.updatetime then firstTimestamp = valveState.updatetime end
if opened then
   fullyOpened = (os.microtime() - firstTimestamp) >= openingValveTime
   if fullyOpened then
       grp.checkwrite(pumpGA, true)
       nextCalculationAfter = minInterval
       grp.checkwrite(pumpGA, false)
       nextCalculationAfter = openingValveTime + 1 - (os.microtime() - firstTimestamp) -- run a little after possible change
log('Next calculation after: ' .. nextCalculationAfter .. 's.')
os.sleep(nextCalculationAfter)
No, it does not work.
there is not any mistake and any error log. Is there the opportunity to have a debug for lua?
What are your settings? It is resident script 0s? Did you tried disable and enable script? Did you add the tag to valves? Do you changed the GA for pump?
When script start it should log such message in the Logs:
Circulation pump calculation 10.03.2018 18:33:49
* string: Next calculation after: 293s.
Done is better than perfect
It is a resident script set at 60 seconds.
Obviously I add tag and change address of pump. In the log I read "next calculation after" but pumps does not start.
(10.03.2018, 18:36)Domoticatorino Wrote: It is a resident script set at 60 seconds.
Please change the time to 0, update script to the newest version, disable and enable it and it must work.
I've checked it and all works perfect. You can also comment this line with log.
Thank you very much. It works!!
Great
valveStatesTagEstate = 'pompa_circolazione_giorno_estate'
valveStatesTagInverno = 'pompa_circolazione_giorno_inverno'
pumpGA = '2/0/1'
openingValveTime = 60 -- time for fully open the valve (maximum time for next calculation)
if stagione == false then
    valveStatesEstate = grp.tag(valveStatesTagEstate)
    for v = 1, #valveStatesEstate, 1 do
     valveStateEstate = valveStatesEstate[v]
     if valveStateEstate.value then
       opened = true
         if firstTimestamp > valveStateEstate.updatetime then firstTimestamp = valveStateEstate.updatetime end
   valveStatesInverno = grp.tag(valveStatesTagInverno)
   for v = 1, #valveStatesInverno, 1 do
     valveStateInverno = valveStatesInverno[v]
     if valveStateInverno.value then
       opened = true
         if firstTimestamp > valveStateInverno.updatetime then firstTimestamp = valveStateInverno.updatetime end
if opened then
   if fullyOpened then
-- log('Next calculation after: ' .. nextCalculationAfter .. 's.')
log(valveStatesEstate)
In your opinion what is wrong in this script above. I add a condition to separate winter condition from summer condition.
I log variable log(valveStatesEstate) but the result is nil. Objects tags are correct and in other 2 scripts (the same) everything works fine.
I cannot understand the reason why it does not working. I expect to read TRUE in log (valveStateEstate).
Thank you for your help.
You are trying to log value 'ValveStatesEstate' but you hasn't defined stagione so stagione equals nil so else condition is executed.
But generally when you extend this script maybe better would be create some function and do script more elastic also for the futureWink
See below (but still you must define stagione!):
pumpGA = '2/0/1'
function getParamsFromValveStates(valvesTag)
    local valveStates = grp.tag(valveStatesTag)
        opened = true
return opened, firstTimestamp
if not stagione then opened, firstTimestamp = getParamsFromValveStates(valveStatesTagEstate)
else opened, firstTimestamp = getParamsFromValveStates(valveStatesTagInverno) end
if opened then
   if fullyOpened then
(24.04.2018, 17:03)buuuudzik Wrote: You are trying to log value 'ValveStatesEstate' but you hasn't defined stagione so stagione equals nil so else condition is executed.
pumpGA = '2/0/1'
        opened = true
if opened then
   if fullyOpened then
Thank you very much...stupid mistake!! I have to hire you  Wink
Nice Smile
How long do you code Lua?
(24.04.2018, 23:24)ODomoticatorino Wrote: How long do you code  Lua?
3-4 years with Logic Machine. Sometimes less sometimes more. But I’ve asked a lot of questions also on this forumSmile Now I like more Javascript than Lua and LM would be for me perfect with modern JS instead the LuaWink
Wow cool. I am using LM for 2 years and I hope to improve my skills in coding.
You are very good. Thanks.
For sure, be patient, try and askWink
Hi there,
I have a big problem with the script below. Please consider that I have 3 same script (obviosly with different varables) and everyting works fine. The one below does not work anymore.
I have seen in the obkect list that last update of group address 2/0/2 was dated 16th of September. The other correctly dated today. I cannot understand the reason why it does not work anymore. And nothing changed.
I tried to delate scritp and redo it without success. I tried to do again object 2/0/2 without success. Nothing group address 2/0/2 never update. Could you help me please?
valveStatesTagEstate = 'pompa_circolazione_mansarda_estate'
valveStatesTagInverno = 'pompa_circolazione_mansarda_inverno'
stagione = grp.getvalue('2/0/100')
pumpGA = '2/0/2'
       opened = true
       opened = true
if opened then
   if fullyOpened then
Add some logging to your script before any grp.checkwrite call. Since it uses grp.checkwrite there won't be any value sent unless it changes.
Ok, log of which variable? Thanks
Add this before os.sleep, this will give some info where the script is going:
log(stagione, opened, os.time(), firstTimestamp)
Please:
log(valveStates)
Maybe you have some error in tags.
(24.10.2018, 12:20)buuuudzik Wrote: Please:
log(valveStates)
Here below the log:
Tesy_pompa_circolazione_mansarda 24.10.2018 14:36:47
* table:
[1]
 * table:
  [export]
   * number: 0
  [disablelog]
   * number: 1
  [tagcache]
   * string: clima, pompa_circolazione_mansarda_inverno, pompa_circolazione_mansarda_estate
  [datahex]
   * string: 00
  [units]
   * string:
  [value]
   * bool: false
  [comment]
   * string:
  [updatetime]
   * number: 1540384570
  [datatype]
   * number: 1009
  [address]
   * string: 2/0/107
  [id]
   * number: 4203
  [data]
   * bool: false
  [highpriolog]
   * number: 0
  [pollinterval]
   * string:
  [readoninit]
   * number: 0
  [name]
   * string: T7 FB Elettrovalvola pavimento mansarda
  [decoded]
   * bool: true
[size=undefined]
* arg: 1
 * bool: true
* arg: 2
 * bool: false
* arg: 3
 * number: 1540384607
* arg: 4
 * number: 0[/size]
The last script you've posted does not have valveStates variable anywhere, please post the latest version that you are using. Also, try turning 2/0/107 on.
