Script - how to end script if true
Hi.
I have some code that i want to stop/exit at first line if true. How is this achived in Lua? I can't find a straight answer for this on google.
if VALUE1 < VALUE2 then "don't go to next if: exit, break, return or something like that"
if VALUE3 < VALUE4 then do something
You can do this on a few ways.
1) You can return before second if
if temp1 < temp2 then   -- do something   return -- could be with some value end if temp3 < temp4 then  -- do something end
2) You can nest your second if in the first
if temp1 < temp2 then -- do something  if temp3 < temp4 then    -- do something  end end
3) If in the first if there is only this secondd you can combine your conditions with AND gate
if temp1 < temp2 and temp3 < temp4 then   -- do something end
Done is better than perfect
Thanks  Smile Nest of the second if was a great solution for my case.
I think now you will write more powerful programsWink
