KNX/TP Error tag
Does anyone made a script for error reporting on the KNX/TP?
I think I've seen it on this forum, but can't find it when it's needed Tongue
Eirik
Try this
function check()  local delta, wdt    wdt = io.readfile('/tmp/tpuart.wdt') or ''    wdt = tonumber(wdt) or 0    delta = os.time() - wdt  return delta <= 10 end checktp = check() log(checktp)
(09.03.2018, 10:20)Daniel. Wrote: Hi
Try this
I have some issue with the connection to TP. It toggles between ERROR/OK all the time.
Any idea what causes this behavior? I have set the electrician to check the connection to see if there is some idmissable connection, but if that is not the case, where to begin the search?
Edit; it seems I am able to send telegrams on the bus even when there is an error in the KNX/TP connection. When I try to change something, I do get a status feedback from the devices.
Trond
It might be a hardware issue. Which LM model are you using? Also measure bus voltage if possible.
(08.11.2018, 08:03)admin Wrote: It might be a hardware issue. Which LM model are you using? Also measure bus voltage if possible.
It is a SpaceLYnk of the HW 1. If I am not mistaken, the FW is 2.1.0
There was a bug in this FW, install any new and problem will be solved.
