Read GA Values from TP-Bus
I'm going crazy at moment. I use several SL with Fw 2.1.1 and I used this Code for read request from TP Bus:
-- only reply to group read requests log('zugriff') --only for testing if event.type == 'groupread' then  log('if schleife') --only for testing  obj = grp.find(event.dst)    -- object found and has datatype set  if obj and obj.decoded then    grp.response(event.dst, obj.value, obj.datatype)  end end
But now I don't get any response if I try to read GA's from diagnostic monitor of ETS.
In my log I get only the output "zugriff" if I write a new value into the GA. But I didn't get any action if I try to read values.
I tried it in different installation, but nothing of them are working any more. One of them is on an old Fw (1.2.1).
Can you help me?
my TP Settings:
[Image: tpsettings.png]
Check that your script has "Execute on group read" enabled.
Of course :-) that was it....  Big Grin
For all who have maybe the same board in front of the head I post the solution in my case:
[Image: readsettings.png]
