Get group value without variable
Hi.
I'm trying to find out how to write the code "if this then" with direct use of group value without using variables.
if grp.getvalue('1/1/84') == false
then do something
The code above is not working
Kai-Roger
It should work only your group 1/1/84 must be a boolean
(17.12.2018, 11:58)Daniel. Wrote: It should work only your group 1/1/84 must be a boolean
Yes you are right. Thanks (:
