LM5Lp2 Disk: 100%
Hi I have a LM5Lp2 but all changes that I try to do, disappear.
In bottom bar appear one more information: Disk: 100% which usually doesn’t appear. If I try to export to another Logic Machine this information doesn’t appear.
When I go to the menu System config -> Status -> System status -> Partitions, the file system “/dev/mtdblock0” is full.
Why it’s happen?
Best regards,
Try updating FW to RC1
How many trends do you have? /dev/mtdblock0 stores databases and trends. You will probably have to delete some trends to free up space for the main database.
(19.12.2018, 11:16)Daniel. Wrote: Hi
This is the Version 20180822. Isn’t it the last?
Best regards,
(19.12.2018, 11:19)admin Wrote: How many trends do you have? /dev/mtdblock0 stores databases and trends. You will probably have to delete some trends to free up space for the main database.
I only have 7 trends. On previous projects I used more and had no problems.
Best regards,
You probably used lower resolution. Change from 5years to 2 and you will shrink it by 3. Latest FW is RC1 20180828
(19.12.2018, 11:54)Daniel. Wrote: You probably used lower resolution. Change from 5years to 2 and you will shrink it by 3. Latest FW is RC1 20180828
I update the FW, delete 5 trends, change the resolution from 5 years to 2, and the disk kept at 100%. After waiting 10 min, I rebooted the LM and the trends appeared again without changes.
Best regards.
You have to sync the project.  Bottom right corner button. Just changing resolution will be fine.
The device with splitted drive for data is available max for 2 years. So there coulnd't be older data than two years. 12*24*365*2=210240. 4136KB/210240 = 20B per one trend row. It's 2x more than I would expected for storing decimals with zero precision. Isn't it a bug?
(19.12.2018, 12:53)Thomas Wrote: Hi
When you create a trend LM reserve already final size for this trend. Even empty trend once created will have final size. Otherwise we will have constant memory problems or disk size.
(19.12.2018, 12:47)Daniel. Wrote: You have to sync the project.  Bottom right corner button. Just changing resolution will be fine.
Previously, I had already do the Sync project data. Now I did it again and it happens again.
Best regards,
Best regards,
Do you mean that still 100%?  If yes can you drop me your project to PM?
