18.03.2019, 21:43
Hi.
Is there a script that can do something if all objects with a certain tag is false?
Kai-Roger
Kai-Roger
If all "tag" objects are false, then
18.03.2019, 21:43
Hi.
Is there a script that can do something if all objects with a certain tag is false? BR Kai-Roger
18.03.2019, 22:03
Try this: Code: tagname = 'tag name'
for _, obj in ipairs(grp.tag(tagname)) do
if obj.value then
return
log('All objects are false')Erwin (18.03.2019, 22:03)Erwin van der Zwart Wrote: Hi, Hi. Thanks a lot! With a lot of trial and error, i finaly got this to do what i want. If all tags are false, then Lights_status is false. If one or more of the tags are true, then Lights_status are true :) tagname = 'Lights_room1' Lights_status = grp.find('1/1/137') for _, obj in ipairs(grp.tag(tagname)) do if obj.value then return Lights_status:write(true) end end Lights_status:write(false) And here a little more adjusted to suite my purpose better in a bigger script, and to work with only tag's (no group adresses) :) for _, obj in ipairs(grp.tag('Lights_room1')) do if obj.value then return grp.tag('All_lights'):write(true) end end grp.tag('All_lights'):write(false)
19.03.2019, 05:39
Are you sure your script works? I would expect the command in true state before the return.. BR, Erwin
19.03.2019, 06:35
(19.03.2019, 05:39)Erwin van der Zwart Wrote: Hi, Hi. Yes it does what i expected. Here is how it responds: But what i failed to do, was to use two of these codes after another in the same code. I think it stops at the first one, so i have to change something so that the scripts run every part of the code.
20.03.2019, 14:13
(19.03.2019, 06:35)Kai-Roger Wrote:(19.03.2019, 05:39)Erwin van der Zwart Wrote: Hi, Not the prettiest script but atleast it works Code: tag = grp.tag('lights_1')
lights_on = 0
-- arraytable = { 'a', 'b', 'c' }
for i, value in ipairs(tag) do
local lights_status = grp.getvalue(value.address)
if lights_status == true then
lights_on = lights_on + 1
if lights_on == 0 then
log('All lights off')
log('Some lights are on')
20.03.2019, 14:54
You don't need grp.getvalue there, each object table already has value field populated.
