Modbus connect with Victron Venus GX controller
Good morning !
I'm trying to read battery State Of Charge from a Victron Venus GX controller with that LUA script :
require('luamodbus') mb = luamodbus.tcp() mb:open('192.168.1.149', 502) mb:connect() r1 = mb:readregisters(843) log (r1) mb:close()
I think the connection is not working, because I get the following message in log :
Venus GX 21.05.2019 09:56:05
* nil
Modbus TCP communication of the Venux GX is working well from my Mac with that Python script :
#!/usr/bin/env python from pymodbus.constants import Defaults from pymodbus.constants import Endian from pymodbus.client.sync import ModbusTcpClient as ModbusClient from pymodbus.payload import BinaryPayloadDecoder Defaults.Timeout = 25 Defaults.Retries = 5 client = ModbusClient('192.168.1.149', port='502') result = client.read_input_registers(843,2) decoder = BinaryPayloadDecoder.fromRegisters(result.registers, byteorder=Endian.Big) r1=decoder.decode_16bit_uint() print("Battery SOC : %d" % (r1))
It's my first time with Modbus TCP on LogicMachine .. so I should have miss something ..
Any help is welcome !
PS/ Here are the Modbus register adresses and types from Victron documentation :
[Image: modbus.jpg]
Why didn't you try to create profile and use modbus mapper? Here are some examples. https://forum.logicmachine.net/showthread.php?tid=839
Creating a profile seems too complicated to me .. but I'll take a look if I got time.
For now, my simple script generate the following error on the Venus GS log :
2019-05-21 09:03:09.810056500 ERROR 2019-05-21T09:03:09.809 "Error processing function code 3, unit id 255, src 192.168.1.100, start address 843, quantity 2 :" "Unit id not found"
I don't see where the set a different unit id .. and which one ?
255 is default slave ID for TCP. Most TCP devices do not care about slave ID. You can set it manually by calling mb:setslave(123) after connect, change 123 as needed.
And try using r1 = mb:readinputregisters(843)
Yes ! it works now with slave ID set to 0 :
require('luamodbus') mb = luamodbus.tcp() mb:open('192.168.1.149', 502) mb:connect() mb:setslave(0) r1 = mb:readregisters(843) r2 = mb:readregisters(808) r3 = mb:readregisters(850) log (r1, r2, r3) mb:close()
Venus GX 21.05.2019 16:10:46
* arg: 1
 * number: 95
* arg: 2
 * number: 265
* arg: 3
 * number: 149
So I'll now be able to process those data the way I want.
Thanks for you help !
