Write/Read KNX IP Interface
I was wondering if it is possible to write/read information directly from 1 or more KNX IP Interfaces that are placed in seperate installations but the same network, by using a script in LM?
LM can tunnel to 1 interface but the downsize is that it will use only this interface. It is much better to use IP router so you can talk to it via multicast.
