28.08.2019, 11:40
admin Wrote:
We will release 2019 RC1 this month
We are waiting
Any short change-log??
We are waiting
![Smile Smile](https://forum.logicmachine.net/images/smilies/smile.png)
[OLD] LogicMachine firmware 2018.08
28.08.2019, 11:40
admin Wrote: We will release 2019 RC1 this month We are waiting ![]()
28.08.2019, 20:30
Hopefully new zwave app, as teased to be released by Easter this year
Sent from my LYA-L29 using Tapatalk
29.08.2019, 08:05
Sadly, new ZWave app will not be a part of new firmware. We'll keep you updated once we have some news.
Change log: 2018.05.16 modbus - fix multiple read for coils / discrete inputs modbus - fix handling of profiles where read_count is smaller than data type width modbus - separate modbus error logs from scripting error logs touch visualization - add home/logout buttons 2018.05.23 object logs - fix source address display, add sender field 2018.06.05 fix storage server not starting up when storage database is corrupt 2018.06.13 fix scripting category filter scroll jumping due to reload 2018.07.12 allow spaces in host name fix internal limit of 8 characters for ftp passwords enocean - change only active button state for "Rocker Switch, 1 Rocker (separate)" profile 2018.07.13 add current ip display and static dns settings to ppp/3g 2018.07.20 allow "@" and "." in user login name 2018.07.27 dali - add 2/3 byte raw telegram support improve shutdown procedure 2018.07.31 modbus - add float64/double support 2018.08.02 fix rgb picker color selection when control is scaled via CSS 2018.08.20 allow usage of 4-bit objects as scene triggers 2018.08.28 change grp.create duplicate name search procedure to ignore case 2018.09.06 dali - fix broken addressing after raw command has been implemented 2018.09.12 luaencdec library - add sha384/sha512 hash/hmac calculation sort widgets/layouts by name instead of creation order 2018.09.18 lm5 rio - fix edge case with object value update when enabling input mode for port that is already in active state 2018.09.21 lmwall - fix sensor values not being displayed fix checkwrite/checkupdate always writing a value when passing non-boolean value to a boolean object 2018.09.28 modbus - remove unused partial xml profile support 2018.10.10 increase maximum user login size from 20 to 50 characters 2018.10.22 increase maximum number of active connections from about 50 to 200 2018.11.16 fix tag event scripts not being executed until saved again when tag is then assigned to a new object fix knx/ip rx telegram counter 2018.11.28 dali - add partial dt8 command support to internal dali library 2018.11.29 add forced https options - either redirect from http to https or http (port 80) disabled completely 2018.12.05 luasocket - add "*r" receive pattern - for lines ending with "\r" ("\n" is ignored) 2018.12.14 add additional garbage collection steps to resident scripts to prevent open file descriptor limit issues 2018.12.21 improve trends deletion/resize procedure to flush data to disk immediately 1-wire - allow seting send delta to 0 (always send new value) 2019.01.10 dali - add Rainbow/Ecodim DALI Lux commands 2019.01.23 dali - add Rainbow/Ecodim DALI Combisence commands 2019.01.25 modbus - fix datatype display in mapping window when object datatype is different from modbus datatype 2019.02.19 modbus - add "float" datatype alias for "float32" 2019.02.20 modbus - add persistent connection mode for TCP devices 2019.02.21 apps - add periodical app update check 2019.03.04 visualization - fix incorrect element size display 2019.03.11 visualization - fix alignment issue between labels and object value text in "value" mode 2019.03.13 schedulers - add multiple scheduler display option for direct link view 2019.03.19 bacnet - fix overridden flag behaviour 2019.04.03 bacnet - fix scale/angle data type maximum value handling, fix 1 byte ASCII character data type fix no value display for objects after custom values have been deleted via mass edit 2019.04.11 lm5ex - fix current measurement incorrect value display when value is negative 2019.05.08 luasocket - add "*c" (custom) receive pattern: second argument is ending character (defaults to \n) third argument character to skip (defaults to \0) 2019.05.21 add quotes around string table keys in log() function, otherwise there's no visual difference between numeric and string keys 2019.05.31 visualization - add remote url option to camera element 2019.06.06 ftp - add forced secure (FTPS) mode vis. graphics - add search scenes - add optional status object object logs - allow wildcard (*) search in object name system config - add system configuration backup/restore 2019.06.14 schedulers - add on/off object for scheduler control visualization - add background color setting for pop-up control elements (sliders, text input, etc) add drag/drop sort via separate window to trends, schedulers, scene sequence and visualization structure 2019.06.28 add brute force protection for HTTP/FTP 2019.07.08 modbus - fix object tag/comment being cleared when mapping an existing object to a modbus register/coil 2019.08.02 add LM5RDC model 2019.08.05 luasocket - set default TLS version to 1.2 for HTTPS requests 2019.08.12 improve LuaSocket HTTP requests: 1. HTTPS is now handled by socket.http.request, ssl.https is not needed for HTTPS anymore 2. Response is returned automatically if no sink is set, setting sink is not needed 3. POST body can be set by adding "body" request key 4. POST body can be a table which will is automatically encoded to a string according to x-www-form-urlencoded format 2019.08.13 trends - show total trend size in MB 2019.08.20 modbus - fix potential out-of-bounds read in slave mode 2019.08.26 fix typos in documented datatypes 2019.08.28 bacnet client - add "command" object type support
Any updates regarding the 2019 release? I own the LM4 - will the release be compatible with my device?
08.10.2019, 20:49
No one answering? Is this forum dead? ?
25.10.2019, 06:12
