[OLD] LogicMachine firmware 2018.08
RC1 is ready for testing. This is mostly a bug fix / stability improvement version.
LM5 Power devices (new CPU)
LM5 Power: https://dl.openrb.com/lm-18-imx6/lm5m3-20180828.img
LM5 Power with extensions: https://dl.openrb.com/lm-18-imx6/lm5m3ex-20180828.img
LM5 Power Reactor Dimmer: https://dl.openrb.com/lm-18-imx6/lm5rd-20180828.img
LM5 Power Reactor IO: https://dl.openrb.com/lm-18-imx6/lm5ra-20180828.img
LM5 Power 4 DIN units: https://dl.openrb.com/lm-18-imx6/lm5m4-20180828.img
Extra packages: https://dl.openrb.com/lm-18-imx6/pkg
Devices with old CPU
LM2 IMX: https://dl.openrb.com/lm-18-mxs/lm2i-20180828.img
LM3 V1 (4 x RS-485): https://dl.openrb.com/lm-18-mxs/lm3v1-20180828.img
LM3 V2 (3 x RS-485 and 1 x RS-232): https://dl.openrb.com/lm-18-mxs/lm3v2-20180828.img
LM4: https://dl.openrb.com/lm-18-mxs/lm4-20180828.img
LM5 lite: https://dl.openrb.com/lm-18-mxs/lm5m3-20180828.img
LM5 lite with extensions: https://dl.openrb.com/lm-18-mxs/lm5m3ex-20180828.img
LM5 4 DIN units: https://dl.openrb.com/lm-18-mxs/lm5m4-20180828.img
LM Ambient: https://dl.openrb.com/lm-18-mxs/lmwall-20180828.img
LM Reactor Lite: https://dl.openrb.com/lm-18-mxs/rctl-20180828.img
LM Reactor V1: https://dl.openrb.com/lm-18-mxs/reactor-20180828.img
LM Reactor V2: https://dl.openrb.com/lm-18-mxs/reactorv2-20180828.img
LM Reactor V3: https://dl.openrb.com/lm-18-mxs/reactorv3-20180828.img
Extra packages: https://dl.openrb.com/lm-18-mxs/pkg
Hi, I tried Dali RAW commands but without success this function is integrated in the Fimware?
Yes, raw is implemented. Can you show the full command that you are using?
ok sorry i found my error i wrote the command to the wrong gateway
running on my LM rector v3 for a day, no issues
I've noticed some changes in the object log, local source address has now been defined in different groups, sr/ss/w1/us
Do you have a definition list`?
Best regards, Jørn.
Is there some kind of release notes, describing what has changed since last years official release?
(01.09.2018, 22:24)rocfusion Wrote: Is there some kind of release notes, describing what has changed since last years official release?
Yes, that would be useful.
@Jørn, here's a list of senders. It might be incomplete, you can use custom sender by setting grp.sender field from scripts (must be two characters).
bt = bluetooth bn = bacnet mb = modbus en = enocean wl = lm wall rc = reactor ek = ekey w1 = 1-wire sc = scenes se = event script ss = scheduled script sr = resident script us = user interface / visualization rm = remote services ap = apps po = group monitor object polling dl = dali
@rocfusion, there are many small bugs fixed, mostly special cases and some security improvements. As for features, ModBus now supports up to 3 serial lines, DALI has 4-bit dimming and raw telegram support, some new profiles added to EnOcean plugin. Right now we are working on Mosaic app improvements.
Nice precisionWink
Done is better than perfect
Hi.
May i ask what "RC1" stands for?
Kai-Roger
Release Candidate 1. RC can become stable release unless some bugs are found. These version are generally safe to install unlike beta/alpha.
Is this with new Z-wave version?
(07.10.2018, 17:12)Bobby Wrote: Is this with new Z-wave version?
Apps are firmware independent and no, right now we work on new Mosaic.
Hi. Is this a new Mosaic, or improvements on the one we are using today?
Kai-Roger
Kai-Roger
Kai-Roger
(08.10.2018, 08:18)Kai-Roger Wrote: Hi. Is this a new Mosaic, or improvements on the one we are using today?
Kai-Roger
Kai-Roger
It is evolution of the current one but we have so many new features so we could call it 3.0.  It is in testing phase so should be out soon.
Nice hope you add possibilities for 0,5 adjusting on widget maker so i can make an advanced thermostat
Kai-Roger
Kai-Roger
(08.10.2018, 08:38)Kai-Roger Wrote: Nice   hope you add possibilities for 0,5 adjusting on widget maker so i can make an advanced thermostat
Kai-Roger
yes Smile
Kai-Roger
Kai-Roger
