Problems with Script Contact Window - Protection Mode
Good morning:
  I made a script so that when a window of a room is opened, the thermostat goes into protection mode.
Once the summer is over, when the heating is switched on and the system is in heating mode the thermostat is put in protection mode even when all the windows are closed, I have no remote connection to the installation but I imagine that the problem is that since LM does not perform the Change from cooling mode to heating mode, any suggestions?
The script is as follows
local ModoCalefaccion = grp.getvalue ("0/1/0")
local ModoTermostato = "6/7/1"
local tagname = 'ContatosVentanacocinasaloncomedor'
if ModoCalefaccion then
  for _, obj in ipairs(grp.tag(tagname)) do  --lee todos los objetos si se cumple la condicion (ventana abierta) pone el termostato en modo proteccion
                                              --si una vez leidos todos no se ha cumplido la condicion escribe en el modo false
                if obj.value then              --Al menos una ventana esta abierta
      grp.checkwrite(ModoTermostato ,true)
      return
                grp.checkwrite(ModoTermostato,false) -- Todas las ventanas estan cerrada
Don't you miss else before
(21.10.2019, 08:20)Daniel. Wrote: Don't you miss else before
 Thank you Daniel for your response, tomorrow I will verify locally if the Script has it with "else" or as I wrote it in the post
 Thank you so much
 Regards
 Checking the script I see ,the return causes it to exit the function so if the first one is fulfilled it does not reach the second
Checking the script , the return causes it to exit the function, so if the first one is fulfilled it does not reach the second.
The error was in a TAG that should not be applied in the D.G."0/1/0"
 Thank you
 B.R.
