LED strip DMX
I need programing a dmx driver with a white LED strip. I need the LED strip to light diode to diode and past some seconds go to turn off diode to diode.
I have a LM Lite 5, a white LED strip and this DMX driver (https://www.amazon.es/gp/product/B00Q1N1...UTF8&psc=1)
I need make somethin like this (https://youtu.be/2GBWmYc__aM?t=13)
Do you have only one DMX driver? If so then this won't work because it can only control 3 separate channels. If you want an animated LEDs you need WS2811 or similar LED strip and a controller suitable for this type of LEDs.
Yes, I have only one DMX driver. But the LED strip is only white color, not RGB. I need other DMX driver too?
The only thing you can do with a 3 channel dimmer is control 3 separate strips. But you can only dim the whole strip at once not separate LEDs.
