Using API canvas HTML
Hello:
Can I use api Canvas HTML in LM?
I want to draw lines and elements using canvas in javascript, how can I get that element?
When I try:
  var icanvas = $('icanvas2').getContext('2d');
  console.log(icanvas)
It doesnt work. How could I use objet canvas in LM?
best regards
Roger
You can do this like below:
const cvs = document.querySelector("icanvas2")
const ctx = cvs.getContext("2d");
console.log(cvs);
Done is better than perfect
(27.10.2019, 22:39)buuuudzik Wrote: You can do this like below:
console.log(cvs);
Hello:
I am trying to draw a simple line, in an element "Frame" in LogicMachine, but I think something is wrong
I try to do this, but  it doesnt work:
const cvs = document.querySelector(".icanvas3")
console.log(cvs);
console.log(ctx);
ctx.moveTo(0,0);
ctx.lineTo(200,100);
ctx.stroke();
Could you help me please?
best regards
And what is the result of below line?
console.log(ctx);
All should work, but you must be sure if canvas is already created. You can add some background in css to it.
(02.11.2019, 08:24)buuuudzik Wrote: And what is the result of below line?
console.log(ctx);
The result in console.log(ctx) is NULL ...
And.. How can add some background in css ???
I just add a frame element in LM, and put in parameter "Additional classes" : icanvas3.
but seem it doesnt work as canvas, any suggestion??
best regards
You have a typo, add a dot before a "icanvas2" if this is a className:
const cvs = document.querySelector(".icanvas2")
Just following this discussion, but when I read it correct you want to draw inside a canvas and you try to do this on a empty iframe. This will never work if you ask me because you need to add a html canvas element in the frame first in my opinion.. You now try to select a non existing element because the iframe is empty..
(02.11.2019, 18:12)buuuudzik Wrote: You have a typo, add a dot before a "icanvas2" if this is a className:
I have tried with this, well as you said, this is a className ".icanvas3", that is in code I add a dot:
console.log(cvs);
console.log(ctx);
ctx.moveTo(0,0);
ctx.stroke();
even so, it doesnt work, console.log(ctx), its result is NULL
best regards
Try this:
1) Create a html named canvas.html with this content
<!DOCTYPE html>
<html>
<body>
<canvas id="myCanvas" width="100%" height="100%" style="border:1px solid #000000;"></canvas>
</body>
</html>
2) Upload canvas.html to the background images tab
3) Create a iframe and add source to: /scada/resources/img/canvas.html
4) Add this code to the custom JavaScript
$(function(){
    $( document ).ready(function() {
      var f= $('iframe')
        f.load(function(){
      const cvs = f.contents().find('#myCanvas')
      console.log(cvs);
      const ctx = cvs[0].getContext("2d");
      console.log(ctx);
      ctx.moveTo(0,0);
      ctx.stroke();
(03.11.2019, 10:26)Erwin van der Zwart Wrote: Hi,
Try this:
<!DOCTYPE html>
<html>
<body>
</body>
</html>
$(function(){
      var f= $('iframe')
        f.load(function(){
      console.log(cvs);
      console.log(ctx);
      ctx.moveTo(0,0);
      ctx.stroke();
Thank you... than you very much, it works ....
best regards
You could use the append function as well: https://api.jquery.com/append/
Try this:
<!DOCTYPE html>
<html>
<body>
</body>
</html>
$(function(){
      var f= $('iframe')
        f.load(function(){
      console.log(cvs);
      console.log(ctx);
      ctx.moveTo(0,0);
      ctx.stroke();
Hi, I have a question about porcentage.
When you put "width="100%" height="100%"" what is the origin? In my frame is a small square.
Here's an example with the Jquery append function that will add an extra div at the left bottom of the widget with id 36 but you can change it to the class or id from every page or widget in your visualization.
To use it you can add it this line of script to your custom Javascript.
$(function() {
  $("#widget-36").append('<div style="position: absolute; bottom: 0; left: 0; z-index: 60;">This text was added to my widget from script</div>');
