result of grp.tag
What is the most efficient way of testing for the table object returned by grp.tag?  ie is it better to test for the existence of the table or the length or is there something else?
if (event.type=='groupwrite') then  local myvl = grp.tag({'VL0','vl'},'all')  if(myvl) then --existence    myvl:write(event.getvalue())  end  local myls = grp.tag({'VL0','ls'},'all')  if(#myls>0) then  --length    if (event.getvalue() > 0) then      myls:write(true)    else      myls:write(false)    end  end end
Thanks,
Roger
grp.tag always returns a table if valid tag, tag list or tag table is passed. So the correct way is to check table length (#mytable). Still, you can call write and other methods on an empty table returned by grp.tag, it just won't do anything.
ok thanks
