(04.02.2020, 12:11)Daniel. Wrote: Do you use PC and a browser or is it a mobile and a mobile network?
I tried both. Both with the same result. No command on bus when i want control anythink from vizualization. Other commands etc. from devices and buttons are in the group monitor and works fine.
Didn't I ? I tried both. Both with the same result. No command on bus when i want control anythink from vizualization. Other commands etc. from devices and buttons are in the group monitor and works fine.
Feedbacks in the vizualization are up to date etc. CO2 but it sends no command when i want do anythink from there. Backup from this "not working good" LM works in another LM (LM5l) in our office fine.
I tried it from my PC via browser (Chrome, Explorer and Opera ) and also on my mobile phone through a mobile network via mobile chrome browser. Both via Remote Access. I am sorry,maybe i don't get your question right.
(04.02.2020, 13:04)Daniel. Wrote: You mention that this is done via port forward, does it work locally?
I am in contact with the owner but i am waiting for the answer on this question regarding a local acces. Now i can´t connect to the LM at all. I deleted cache several times before. Now it looks like a death sd card? I will change the sd card and let you guys know. Thanks for the support.
Check what is in your Browser console. Right mouse button and select "Inspect". Then on left side you have console which could have some info about the purpose of your issue.
Have a problem with bacnet.readvalue. Now it`s return string like this "string: RX: 192.168.252.32 16 RX: 192.168.252.5 20 APDU: 16 0 196 RX: 192.168.252.5 23 APDU: 48 1 12 -0.838248"
@johanax, you need reactor V1. IO list for each model:
V1: 16x digital out, 6x resistive, 7x analog in, 2x analog out
V2: 16x digital in/out, 6x pt1000, 2x analog out
V3: 16x digital in/out, 6x analog in, 2x analog out
(09.02.2020, 12:22)admin Wrote: @johanax, you need reactor V1. IO list for each model:
(04.02.2020, 13:34)Daniel. Wrote: This what you described sound like websocket is blocked by something but if device is damaged then yes that could be the issue.
Hi Daniel, you were right. It was somewhere in the websocket. Now i am on VPN and it works absolutly fine. Either the microsd card is not damaged. THX for the support.
I have a old LM2 (LM2V3Mv1.5 / LM2202E041) (KNXLM2CT).
Is there any new firmware for this?
Now it's running 20170601. I have tested with the firmware for LM2 IMX but get fault message that "firmware image file is invalid"
This is latest FW available for old LM2 devices: https://dl.openrb.com/lm-18-at91/20181002.img
RC firmware will not be provided for these devices. There might be a final 2020 build for it but I cannot guarantee this as device is in EOL status.
Hello!
Can you help to enable/disable modbus correctly?
Scenario. In case of prolonged absence, I turn off the power ventilation and the modbus reports an error every 5 seconds.
The solution was a script in firmware 201706:
value = grp.getvalue('32/0/15')
require('uci')
require('json')
function getvar()
return 'config-save'
function json.data()
return { enabled = value }
dofile('/lib/genohm-scada/plugins/modbus/web.lua')
In the new firmware it does not work correctly.
He really turns off the modbus.
But it can’t turn it on.
The RTU1 checkbox is enabled, but no data is received even when trying to read RTU - a message: RTU(serial) is not enabled.
Solution - manually disable and enable RTU1 checkbox.
How to correctly enable/disable RTUx from a script?
18.02.2020, 14:38 (This post was last modified: 18.02.2020, 15:02 by stonecroft.)
(14.02.2020, 12:13)admin Wrote: This is latest FW available for old LM2 devices: https://dl.openrb.com/lm-18-at91/20181002.img
everything seems to work but when i try to implement modbus comunication the system status page dont show any serial port names.
Sure, this question may sound very trivial to most of this forum's members, but to me as a newcomer many things are to be learned - such as;
in case of a FW-upgrade, what package should be installed on a "LogicMachine5 Power KNX CANx"?
Power means it's i.MX6 CPU (new CPU)
Regular one is i.MX28 (old CPU)
HW: LM5 Lite means it needs to use LM5 Lite firmware HW: LM5 Lite + ext means it need to use LM5 with extension firmware (includes devices LM5-KC, LM5-DW1, LM5-DR, LM5-PMC, and old type LM5-RIO which is discontinued) HW: LM5 M4 means it need to use LM5 4 DIN firmware (it's long time ago discontinued product)
Your camera uses outdated SSLv3 protocol which has been disabled for security reasons. If your camera does not support TLS then the only solution is to use plain HTTP instead of HTTPS.
