SpaceLYnk Telegram
We have Telegram API working on LogicMachines. We copy the same code on SpaceLynk and it not works..
Is posible to make it work on SpaceLynk?
Thanks!
Check your network settings. Make sure you have a working internet connection at your spaceLYnk. If it can't communicate to the internet it can't communicate with the API or if it's a local device make sure your spaceLYnk is in the same network as your API device (like Philips Hue gridge or so).
Network is OK.
Code used is:
local telegram_url = 'https://api.telegram.org/'..token_bot..'/sendMessage?'
function telegram(message)
  local data_str = 'chat_id=' .. chat_id .. '&text=' .. message..''
  local res, code, headers, status = ssl.https.request(telegram_url, data_str)
log (res,code,headers,status)
Log Response:
* arg: 1
  * nil
* arg: 2
  * string: error:1409442E:lib(20):func(148):reason(1070)
* arg: 3
  * nil
* arg: 4
  * nil
Not working!
Thanks!
