27.07.2020, 09:56
I would likde to make a script for a swimming pool heat pump.
If this works for 6 hours (33/0/1 1Bit object input ON/OFF Pump) then we controle after the filtration for 6 hours (33/0/2 1 bit object output ON / OFF Filtration).
You must be able to modify the desired time 12H in this example (6H + 6H)
This count must be reset to 0 every Day.
Best regards.
Gadjoken.
Best regards.
Gadjoken.
