Epson projector tcp / ip control help
hi,
i having trouble connecting to an epson tw9400 projector via tcp /ip,  i've been able get to PJ Link working (turning the projector on/ off), but i require extra commands that the PJ link doesn't support (lens control, key functions.etc)
the projector requires a handshake to enable ESC/VP.net before it will accept commands, i've been able to verify connection to the projector via the Hercules setup utility below,
this is the instructions on how to connect to the projector via ESC/VP.net, i've also attached the ESC/VP command list below
But i haven't been able to make a connection via the logicmachine
the handshake is -  [i]ESC/VP.net<DLE><ETX><NUL><NUL><NUL><NUL>[/i]  or HEX = 45 53 43 2F 56 50 2E 6E 65 74 10 03 00 00 00 00
and this where i'm at the moment, i've modified the Pj Link script,  changing the port to 3629, but i'm not sure how to implement the handshake into the script?
any help would be much appreciated
1234567891011121314151617181920212223242526272829303132
require('socket') value = event.getvalue() ip = '192.168.1.64' port = 3629 if value == 255 then   cmd = 'PWR ON<CR>' --Power On end if value == 250 then   cmd = 'PWR OFF<CR>'  --Power Off end sock = socket.tcp() sock:settimeout(1) res, err = sock:connect(ip, port) if res then   res, err = sock:send(cmd)   if res then     alert('Send OK')   else     alert('Send failed: %s', tostring(err))   end else   alert('Connect failed: %s', tostring(err)) end
.xlsx   ESCVP21 command .xlsx (Size: 215.57 KB / Downloads: 9)
You can convert hex char codes to a string like this:
hs = string.char(0x45, 0x53, 0x43, 0x2F, 0x56, 0x50, 0x2E, 0x6E, 0x65, 0x74, 0x10, 0x03, 0x00, 0x00, 0x00, 0x00)
Then you need to send it before the actual command:
res, err = sock:send(hs) res, err = sock:send(cmd)
Note that anything between <> is not a string value but an ASCII character name, so 'PWR OFF<CR>' should actually be 'PWR OFF\r'
(02.09.2020, 11:43)admin Wrote: You can convert hex char codes to a string like this:
Awesome - thank you very much for you help! Big Grin Big Grin
