grp.listen init, value
I've found that grp.listen() when when it has last optional param set to true, then it initially runs 2 times: 1) state=="init", 2) state=="value"
I think state=="value" should only run when value change or update on a bus, this is logically separated from "init".
Done is better than perfect
This is intended behavior. You can ignore init state and/or use a variable to check if this is the first time that callback is called.
Hi!
Is there any way to use grp.listen() when an object updates but not changes?
I´m doing a emergent notification and many times the message is the same. Object updates but function inside JS doesn´t run.
grp.listen("33/1/255", function(object,state) {     if (state == 'value') {       console.log('Show message')       setTimeout(function(){        console.log('Hide Messase')       }, 4500);     } });
Add a third argument (true) to grp.listen to catch all messages. You also need to clear the timeout on each value update otherwise your function won't work correctly.
$(function() {   var timeout;   grp.listen("33/1/255", function(object,state) {     if (state == 'value') {       console.log('Show message');       clearTimeout(timeout);       timeout = setTimeout(function(){        console.log('Hide Messase');       }, 4500);     }   }, true); });
(09.12.2020, 09:28)admin Wrote: Add a third argument (true) to grp.listen to catch all messages. You also need to clear the timeout on each value update otherwise your function won't work correctly.
Ok Thanks!
