Read RS232 send to KNX Group adress
Hi.
Is it anyone who knows how to read from RS232 and send forward to a KNX group adress.
i will receive 4 different values that should call for a scene on the KNX side....
0/r, 1/r, 2/r and 3/r, i have seen some script examples but how do i make it send to the KNX group adress
require('serial')
port = serial.open('/dev/RS232', {
  baudrate = 38400,
  databits = 8,
  stopbits = 1,
  parity = 'none',
  duplex = 'full'
This must be to open the port, but the rest i don`t know how, i think it must be some "port:read" and  "write to"
Best regards
Serial docs: https://openrb.com/docs/serial.htm
Thanks, but how do i transfer received value to KNX group adress ?
It depend of the application. You may need to convert the data and then write to object as to any other object. The simplest way is to make If received string is X then write to object Y etc.
See this example: https://forum.logicmachine.net/showthrea...24#pid4224
You just need to add several if's and grp.write calls
Ok, i will try and reply how it goes
I tried this script.... but something must be wrong in the log it says "* string: port not open"
Try this script (resident, sleep time = 0) as is without changing anything and post what you get in Alerts tab:
1234567891011121314151617
if not port then   require('serial')   port = serial.open('/dev/RS232', { baudrate = 9600 })   port:flush()   line = '' end char = port:read(1, 1) if char then   if char == '\r' then     line = line:trim()     alert(line)     line = ''   else     line = line .. char   end end
I got nothing in the log ....
Are you sure that data is being sent to the port? Try this and post what you get in Logs tab.
if not port then   require('serial')   port = serial.open('/dev/RS232', { baudrate = 9600 })   port:flush()   line = '' end char, err = port:read(1, 60) log(char, err)
This came up now...
This should accept strings in X/r format where X is a number between 0 and 3:
char = port:read(1, 1) if char then   if char == 'r' then     if #line == 2 and line:sub(2, 2) == '/' then       value = tonumber(line:sub(1, 1))              if value and value >= 0 and value <= 3 then         grp.write('1/1/1', value)       end     end     alert(line)     line = ''   else     line = line .. char   end end
And before this it should be to open the port ?
Yes this
Ok, sorry but i get nothing now on the log, i don´t know what is wrong.
Check alerts not logs. Start logging the object 1/1/1 or which ever you used in the script
This is how the script looks now..
Anything in the Alerts tab? Add a new line with log(line) after if char then, and post what you get in the Logs tab
I had some things between will check it on monday.
TY
Hi, the problem is solved the script is working fine....   Big Grin
Thank you very much for the support
//Anders
