W to kw formel
I made a simple math scritp, it worked fine.
But when i have negativ -W = when i produced sunpower the -w turns in to positiv in my kw formel. Why?
So
-30+-30+-30=-90w -90w/1000 should be =-0,090kw but the results is 0,090kw
Thanks[Image: fe746642b074a360b70ba5d837093ba5.jpg]
Skickat från min SM-G981B via Tapatalk
(28.02.2021, 09:14)P3774n Wrote: Hi
So
I think because you are use abs.math function
Ok, with formel it best suteed here?
Math.floor its not the answare.
Update math.floor is working. But it rounds up
If you use value = value4 / 1000
doesn't it work?
Problem solved, a little embarresing. Just add - and not run a math function....
