Subtract 30 minutes from time value - 2021-05-12T19:30:00
I receive time values from an API in the following format
2021-05-12T19:30:00
How can I subtract 30 minutes from the time (and also correct for date for when I receive midnight value?)
Many thanks in advance
James
Use this:
123456789101112131415
str = '2021-06-01T00:00:00' date = {} -- assign table keys for further conversion date.year, date.month, date.day, date.hour, date.min, date.sec =   str:match('(%d+)-(%d+)-(%d+)T(%d+):(%d+):(%d+)') -- convert to unix timestamp and subtract 30 minutes in seconds timestamp = os.time(date) - 30 * 60 -- convert timestamp to table date = os.date('*t', timestamp) log(date)
This seems to return the date as a table.
12345678910111213141516171819
* table: [sec]   * number: 0 [min]   * number: 0 [day]   * number: 12 [isdst]   * bool: false [wday]   * number: 4 [yday]   * number: 132 [year]   * number: 2021 [month]   * number: 5 [hour]   * number: 19
How can I convert this back to a string in the same format as the original time (ie: 2021-05-12T19:30:00 > 2021-05-12T19:00:00)?
Many thanks
James
1234567891011121314
str = '2021-06-01T00:00:00' date = {} -- assign table keys for further conversion date.year, date.month, date.day, date.hour, date.min, date.sec =   str:match('(%d+)-(%d+)-(%d+)T(%d+):(%d+):(%d+)') -- convert to unix timestamp and subtract 30 minutes in seconds timestamp = os.time(date) - 30 * 60 -- convert timestamp to string result = os.date('%Y-%m-%dT%H:%M:%S', timestamp) log(result)
This worked perfectly! Many thanks
