Best way to decode Modbus
I have a DSE7320 power generator controller and i need to read some alerts.
I use Modbus mapper to store the alert registers to virtual objects and then decode them with script.
dword ='0x'.. event.datahex myobject = grp.find(event.dstraw) function getbit(value, nr)   value = bit.rshift(value, nr)   return bit.band(value, 1) end for i = 0, 15, 4 do   obj=math.floor((i+1)/4)   msg=''   val=''   for x = 0, 3, 1 do     ix=i+x       val = getbit(dword,ix)..val   end   bin = string.reverse(val)     local sum = 0     for i = 1, string.len(bin) do       num = string.sub(bin, i,i) == "1" and 1 or 0         sum = sum + num * math.pow(2, i-1)     end     msg=msg .. ' Bin:'..val..' Dec:'.. sum     obj=obj..msg   alert(myobject.name..'-'..obj) end
Can someone please verify if this is the most eficient way or sugest something better?
Thank you in advance
George
The most correct way to do this is via bit shifts (bit.rshift and bit.band) but since you need to split the value into 4 bit values you can simply use the datahex string:
value = event.datahex values = {} for i = 1, 4 do   char = value:sub(i, i)   values[ i ] = tonumber(char, 16) end log(values)
