access a page with the username or password in the url
HI:
I have a client with visual problems and I would like to create a shortcut with username and password in the url.
There are browsers, such as chrome, that do not allow you access in the usual way http: // user: pass@www.xxx.xx
Thanks in advance
Best regards
On mobile or tablet, use LogicMAchine app.
HI:
It isn't possible use mobile o tablet. He has a special program in his computer to control it, not compatible with mobile o app. He has a problem of vision so is worst use this kind of devices.
If using Chrome, you can create a shortcut and add these parameters to the shortcut target (after ...chrome.exe"):
--disable-blink-features="BlockCredentialedSubresources"
Perfect.
Best regards
(22.07.2021, 06:45)admin Wrote: If using Chrome, you can create a shortcut and add these parameters to the shortcut target (after ...chrome.exe"):
offtopic,
kun je dit ook gebruiken om camera beelden te bekijken met het wachtwoord en username in de link via de wiser for knx of de LM?
