Yamaha Extended Control
I can send HTTP a request to the Yamaha controller.
http://ip_address/YamahaExtendedControl/.../getStatus
After the request, I receive an answer. For example when "power": "ON", the controller is on, and when "power": "standby" the controller is off.
{"response_code":0,"power":"standby","sleep":0,"volume":100,"mute":false,"max_volume":161,"input":"airplay","input_text":"AirPlay","distribution_enable":false,"enhancer":true,"equalizer":{"mode":"auto","low":0,"mid":0,"high":0},"bass_extension":false,"link_control":"standard","link_audio_delay":"balanced","disable_flags":0,"actual_volume":{"mode":"db","value":-30.5,"unit":"dB"},"mono":false}
Tell me how I can convert the received data to the KNX?
Use this as a starting point. response variable should contain your HTTP request result.
status = require('json').pdecode(response) if type(status) == 'table' then   poweron = status.power ~= 'standby'   grp.checkupdate('1/1/1', poweron) -- power status (1 bit)   grp.checkupdate('1/1/2', status.input_text) -- input (text)   volume = status.volume / status.max_volume * 100   grp.checkupdate('1/1/3', volume) -- current volume (1 byte scale) end
thanks.
Volume status problem!
The volume volume status is 100 but received volume value is 61
Therefore, the script is constantly updating the value.
Try using the volume value directly. Also you should use different objects for status and control.
grp.checkupdate('1/1/3', status.volume)
