Threads: 24
Hi @all,
I looking around to get a weather service including for free forecasts and found out that there is a new option using openweather ONE call API:
https://openweathermap.org/api/one-call-api
Is somebody having experience with it and can help me with a working script to start with?
Many thanks for your help!
Best Regards
Steffen
Threads: 43
Threads: 16
Threads: 24
Many thanks for your help. I will try this the next days and give you a feedback if it works.
Threads: 24
Hi @all,
due to the great hints of you guys I got the first script running for the current temperature and humidity value.
Now I want to get also the current weather description and the daily forecast for temperature min and max.
Unfortunately this values are not working. In the script log I see the following message:
User script :
39 :
attempt to index field 'temp' (
a nil value )
stack traceback :
Here is my actual script:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41
require (
'json' )
http =
require (
'socket.http' )
appid =
'XXX'
lat =
'XXX'
lon =
'XXX'
lang =
'en'
units =
'metric'
url =
'http://api.openweathermap.org/data/2.5/onecall?lat=%s&lon=%s&units=%s&lang=%s&appid=%s'
url =
string.format (
url ,
lat ,
lon ,
units ,
lang ,
appid )
res ,
code ,
headers ,
status =
http.request (
url )
log (
code ,
status ,
headers )
data =
json.pdecode (
res )
if not data then
alert (
'Error converting data' )
return
if not res then
alert (
'Error collecting data' )
return
current =
data.current
daily =
data.daily
grp.write (
'41/1/1' ,
current.temp )
grp.write (
'41/1/2' ,
current.weather.description )
grp.write (
'41/1/3' ,
current.humidity )
grp.write (
'41/1/4' ,
daily.temp.min )
grp.write (
'41/1/5' ,
daily.temp.max )
Do you have an idea what might be wrong?
Best Regards
Steffen
Threads: 43
Try replacing line 29 with this:
Threads: 24
Many thanks for the help!
Now the daily temperature predictions are working! Unfortunately the daily.weather group e.g. daily.weather.description is not getting a result. I played around with the datatypes (250 byte string, 14 byte string) with no effect.
Any idea what I can do?
Threads: 43
Use daily.weather[1].description
Threads: 24
22.10.2021, 09:27
(This post was last modified: 22.10.2021, 09:54 by pioneersteffen .)
Many thanks for the help, it works fine now!
Here is the finished script for other users to continue with it:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
require (
'json' )
http =
require (
'socket.http' )
appid =
'XXX'
lat =
'XXX'
lon =
'XXX'
lang =
'de'
units =
'metric'
url =
url =
string.format (
url ,
lat ,
lon ,
units ,
lang ,
appid )
res ,
code ,
headers ,
status =
http.request (
url )
log (
code ,
status ,
headers )
data =
json.pdecode (
res )
if not data then
alert (
return
if not res then
alert (
return
current =
data.current
daily =
data.daily [
1 ]
grp.write (
'41/1/1' ,
current.temp )
grp.write (
'41/1/3' ,
current.humidity )
grp.write (
'41/1/6' ,
current.wind_speed )
grp.write (
'41/1/4' ,
daily.temp.min )
grp.write (
'41/1/5' ,
daily.temp.max )
grp.write (
'41/1/2' ,
daily.weather [
1 ].
description )
One last rookie question. I want to combine current.temp + current.humidity + current.wind_speed to one string and send this via a 14 byte ASCII group adress.
How would this look like?
Found the solution on my own, here is a line to combine the values:
wetterprognose = daily.temp.min.."/"..daily.temp.max
Threads: 24
I trying to integrate the alerts as well. Unfortuantely I getting the following error:
Openweathermap 22.10.2021 19 :
39 :
38
User script :
52 :
attempt to index global 'alerts' (
a nil value )
stack traceback :
User script :
52 :
in main chunk
Here is the complete code:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57
require (
'json' )
http =
require (
'socket.http' )
appid =
'xxx'
lat =
'xxx'
lon =
'xxx'
lang =
'de'
units =
'metric'
url =
url =
string.format (
url ,
lat ,
lon ,
units ,
lang ,
appid )
res ,
code ,
headers ,
status =
http.request (
url )
log (
code ,
status ,
headers )
data =
json.pdecode (
res )
if not data then
alert (
return
if not res then
alert (
return
current =
data.current
daily =
data.daily [
1 ]
alerts =
data.alerts
grp.write (
'41/1/1' ,
current.temp )
grp.write (
'41/1/3' ,
current.humidity )
grp.write (
'41/1/6' ,
grp.write (
'41/1/4' ,
daily.temp.min )
grp.write (
'41/1/5' ,
daily.temp.max )
grp.write (
'41/1/2' ,
daily.weather [
1 ].
description )
grp.write (
'41/1/7' ,
daily.wind_gust )
grp.write (
'41/1/8' ,
daily.uvi )
grp.write (
'41/1/9' ,
daily.rain )
grp.write (
'41/1/10' ,
alerts.event )
wetterprognose =
math.ceil (
daily.temp.min )..
math.ceil (
daily.temp.max )..
daily.rain.. "/" ..
math.ceil (
daily.wind_gust )..
math.ceil (
daily.uvi )
grp.write (
'41/2/1' ,
wetterprognose )
Best Regards
Steffen
Threads: 24
Additional to post #10 I got a the same problem with the "rain" value today. Yesterday it worked fine due to rain = 4.31. Today there is no rain predicted. The failure is calling:
User script :
54 :
attempt to concatenate field 'rain' (
a nil value )
stack traceback :
User script :
54 :
in main chunk
Can you help me with an idea for a solution please?
Many thanks!
Threads: 43
Replace
daily.rain with
(daily.rain or 0)
Alerts might not be available so an extra check is needed:
if type (
alerts ) ==
'table' and type (
alerts [
1 ]) ==
'table' then
alert_event =
alerts [
1 ].
event
grp.write (
'41/1/10' ,
alert_event or '' )
Threads: 24
Many thanks for the help! It is working now.
Here my complete script for all other users to continue with it:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
require (
'json' )
http =
require (
'socket.http' )
appid =
'xxxx'
lat =
'xxx'
lon =
'xxx'
lang =
'de'
units =
'metric'
url =
url =
string.format (
url ,
lat ,
lon ,
units ,
lang ,
appid )
res ,
code ,
headers ,
status =
http.request (
url )
log (
code ,
status ,
headers )
data =
json.pdecode (
res )
if not data then
alert (
return
if not res then
alert (
return
current =
data.current
daily =
data.daily [
1 ]
alerts =
data.alerts
grp.write (
'41/1/1' ,
current.temp )
grp.write (
'41/1/3' ,
current.humidity )
grp.write (
'41/1/6' ,
grp.write (
'41/1/4' ,
daily.temp.min )
grp.write (
'41/1/5' ,
daily.temp.max )
grp.write (
'41/1/2' ,
daily.weather [
1 ].
description )
grp.write (
'41/1/7' ,
daily.wind_gust )
grp.write (
'41/1/8' ,
daily.uvi )
grp.write (
'41/1/9' , (
daily.rain or 0 ))
if type (
alerts ) ==
'table' and type (
alerts [
1 ]) ==
'table' then
alert_event =
alerts [
1 ].
event
grp.write (
'41/1/10' ,
alert_event or '' )
wetterprognose =
math.ceil (
daily.temp.min )..
math.ceil (
daily.temp.max )..
daily.rain or 0 )..
math.ceil (
daily.wind_gust )..
math.ceil (
daily.uvi )
grp.write (
'7/2/3' ,
wetterprognose )
Threads: 7
28.10.2021, 10:40
(This post was last modified: 28.10.2021, 10:43 by Erwin van der Zwart .)
I would change all grp.write into grp.checkupdate, this avoids all objects being updated each run when values are not changed and you have a lot of unneeded KNX telegrams on your TP bus (i assume most are for visu only), for the values you realy need on the bus you should use grp.checkwrite
Threads: 83
Hi Erwin,
Sorry, not directly to this topic, but linked with weather data.
how better organize checking that weather data are updating (correctly)? I will install weather station first time, before I usually used different weather services. Of course I saw simply way once per hour check as example wind speed, and if data not changing - than do alert. But weather station sends data constantly and 1 hour checking period will be long? I just thing how correctly configure weather station to send data and not to overload KNX line.. Send data only if changed or cyclically every 10 minutes send them again? Script I found for data check:
I would add a check to be sure that the values from the online service are received as expected, we do the same with a signal from a local weather station (alive signal).
Make a resident / scheduled script at like this:
lastupdate = grp.find('1/1/1').updatetime
difference = os.time() - lastupdate
if difference > then 3600 then -- 1 hour not changed
alert('No new value received from online weather service')
-- or mail / push / sms etcetera
What is recommendation for local weather station?
BR, Alexander
Threads: 7
31.10.2021, 07:24
(This post was last modified: 31.10.2021, 07:27 by Erwin van der Zwart .)
Not sure what KNX weather station you have, but our KNX weather station has this alarming in the application and there is no scripting required.. have you checked the ETS application already for possible settings? From this alarm object you can simply trigger your email script or trigger the alert manager.
Threads: 83
Thank you Erwin, will check again possibility of my weather station.
Alexander
Threads: 24
Hi @all,
I want to get the snow fall forecast for the next 24h unfortunately I struggling to address the table position right.
What would be the right address for the snow value?
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89
table :
1 ]
table :
"feels_like" ]
number : -
4.82
"dew_point" ]
number :
0.53
"snow" ]
table :
"1h" ]
number :
0.1
"pop" ]
number :
0.34
"humidity" ]
number :
95
"weather" ]
table :
1 ]
table :
"main" ]
string :
Snow
"description" ]
string :
M äß
iger Schnee
"icon" ]
string :
13d
"id" ]
number :
600
"uvi" ]
number :
"wind_gust" ]
number :
13.94
"wind_deg" ]
number :
266
"pressure" ]
number :
993
"wind_speed" ]
number :
8.29
"temp" ]
number :
1.24
"visibility" ]
number :
10000
"clouds" ]
number :
98
"dt" ]
number :
1705305600
2 ]
table :
"feels_like" ]
number : -
4.51
"dew_point" ]
number :
0.5
"snow" ]
table :
"1h" ]
number :
0.13
"pop" ]
number :
0.49
"humidity" ]
number :
94
"weather" ]
table :
1 ]
table :
"main" ]
string :
Snow
"description" ]
string :
M äß
iger Schnee
"icon" ]
string :
13d
"id" ]
number :
600
"uvi" ]
number :
0.2
"wind_gust" ]
number :
13.92
"wind_deg" ]
number :
264
"pressure" ]
number :
992
"wind_speed" ]
number :
7.88
"temp" ]
number :
1.36
"visibility" ]
number :
277
"clouds" ]
number :
100
"dt" ]
number :
1705309200
I‘ve tried the following:
But getting the failure:
Lua syntax error at line 79 :
malformed number near '.1h'
Best Regards
Steffen
Threads: 43
Use this:
data.hourly [
i ].
snow [
'1h' ]
Threads: 24
15.01.2024, 10:23
(This post was last modified: 15.01.2024, 10:27 by pioneersteffen .)
(15.01.2024, 09:14) admin Wrote: Use this:
data.hourly [
i ].
snow [
'1h' ]
Many thanks! This idea work, but I have a problem in the case of The value doesn’t exist because there is no snow forecasted = nil.
I tried this one:
repeat
i =
i +
if data.hourly [
i ].
snow [
'1h' ] ==
nil
then
data.hourly [
i ].
snow [
'1h' ] =
log (
data.hourly [
i ].
snow [
'1h' ])
snowsum =
data.hourly [
i ].
snow [
'1h' ] +
snowsum
until
i >
24
but it doesn’t work.
User script :
83 :
attempt to index field 'snow' (
a nil value )
stack traceback :
Do you have an idea please?
Many thanks!
