change the opacity of a text
hello
I used this JS code to change the objects to read only and change the opacity, but it didnt change the opacity of a text
how to make it work in text also
$(function(){
  grp.listen('32/1/1', function(object) {
     if (object.value == true ) {
        $(".lockbyknx").addClass("item-read-only");
         $(".lockbyknx").find('img').css("opacity", 0.5);
     } else if (object.value == false ) {
        $(".lockbyknx").removeClass("item-read-only");
         $(".lockbyknx").find('img').css("opacity", 1);
  }, true); // set to true to send on same value
Best Regards,
Custom JS:
$(function(){
    $(".lockbyknx").toggleClass("item-read-only", object.value == true);
Custom CSS:
.item-read-only {
  opacity: 0.5 !important;
Thanks admin
But it changed the opacity of all read only values
I want to change the opacity of values with "lockbyknx"
regards,
edit: I changed the CC
/* Change Opacity*/
.lockbyknx {
  opacity: 0.3 !important;
Best Regards,
Use this:
.lockbyknx.item-read-only {
(18.11.2021, 12:02)admin Wrote: Use this:
thanks admin
Best Regards,
How can I remove the + and - button from a direct input box ?
This will hide buttons from all input boxes:
.control-spinner .btn { display: none; }
