HTTP Post
How can I send POST command "POST /relay/0?turn=on" from lua script?
Deso
One of these requests should work for you, don't forget to change the IP address as required.
local http = require('socket.http') -- empty post body http.request('http://192.168.1.1/relay/0?turn=on', '') -- post instead of get http.request('http://192.168.1.1/relay/0', 'turn=on') -- post and get http.request('http://192.168.1.1/relay/0?turn=on', 'turn=on')
Thanks, it work. Is there any manual or examples about http post and get?
Here's the library reference:
http://w3.impa.br/~diego/software/luasoc...ml#request
(07.11.2016, 07:17)admin Wrote: Here's the library reference:
Hello Admin,
I would like to send by order on a second LM or on another box (Box TV) i use this script but the command is not sent.
I indicate the IP and the password but the request is not sent.
I try directly in the browser and it works.
these scripts are still functional?
http.request('http://remote:remote@IP/scada-remote?m=json&r=grp&fn=write&alias=34/1/2&value=1', '')
thanks.
B.R.
Are you referring to remote services? Sure they work, fallow this
https://forum.logicmachine.net/showthrea...09#pid3009
Add log call to see what the web server returned in Logs tab:
local http = require('socket.http') res, err = http.request('http://remote:remote@IP/scada-remote?m=json&r=grp&fn=write&alias=34/1/2&value=1') log(res, err)
(09.05.2019, 10:09)admin Wrote: Add log call to see what the web server returned in Logs tab:
Can be then admin login request ?
Log :
* arg: 1
 * nil
* arg: 2
 * string: connection refused
Connection refused means that URL has incorrect IP or port (optional, default 80). Can you ping that IP from System config > Status > Network utilities?
(09.05.2019, 11:53)admin Wrote: Connection refused means that URL has incorrect IP or port (optional, default 80). Can you ping that IP from System config > Status > Network utilities?
it works with the local IP but not the public one I do not know why. I continue my tests. With the FREEPLAYER i have :
* arg: 1
 * string:
* arg: 2
 * number: 403
Do you mean that you use port forwarding? Are two devices in the same sub-network and you want to access another device via port-forwarded IP?
(09.05.2019, 12:18)admin Wrote: Do you mean that you use port forwarding? Are two devices in the same sub-network and you want to access another device via port-forwarded IP?
No for example I have an LM in the same network as the player freebox and I would like to drive via the LM this player.
So I have the following script (For the remote I did my tests for sending URLs because it did not work with the player, to be sure I was not wrong in the scripts).
   local http = require('socket.http')         res, err = http.request('http://http://IPLOCAL/pub/remote_control?code=CODETELECOMMAND"&key=play')     log(res, err) --[[ "red" // Bouton rouge "green" // Bouton vert "blue" // Bouton bleu "yellow" // Bouton jaune "power" // Bouton Power "list" // Affichage de la liste des chaines "tv" // Bouton tv "1" // Bouton 1 "2" // Bouton 2 "3" // Bouton 3 "4" // Bouton 4 "5" // Bouton 5 "6" // Bouton 6 "7" // Bouton 7 "8" // Bouton 8 "9" // Bouton 9 "back" // Bouton jaune (retour) "0" // Bouton 0 "swap" // Bouton swap "info" // Bouton info "epg" // Bouton epg (fct+) "mail" // Bouton mail "media" // Bouton media (fct+) "help" // Bouton help "options" // Bouton options (fct+) "pip" // Bouton pip "vol_inc" // Bouton volume + "vol_dec" // Bouton volume - "ok" // Bouton ok "up" // Bouton haut "right" // Bouton droite "down" // Bouton bas "left" // Bouton gauche "prgm_inc" //Bouton programme + "prgm_dec" // Bouton programme - "mute" // Bouton sourdine "home" // Bouton Free "rec" // Bouton Rec "bwd" // Bouton << retour arrière "prev" // Bouton |<< précédent "play" // Bouton Lecture / Pause "fwd" // Bouton >> avance rapide "next" // Bouton >>| suivant --]]
When I realize it directly in my browser it works.
Your URL has http:// twice and there's a double quote character in code argument: code=CODETELECOMMAND"
(09.05.2019, 13:05)admin Wrote: Your URL has http:// twice and there's a double quote character in code argument: code=CODETELECOMMAND"
Yes i have a single http lack of copy.
it's the " who's causing the problem...
(Sorry for making you waste yout time !!!!)
it works perfectly.
One las question concerning all of thse commands how can i easily reduce the script and not put if 1 then play if 2 then power if 3 .... etc...
can we recover the names of the custom values in order to put in my URL according to the command achieve?
Thanks a lot.
BR.
There's no easy way of accessing custom values. But you can create a table with number - key mapping:
keys = {   [0] = 'stop',   [1] = 'play', } val = event.getvalue() key = keys[ val ] if key then   local http = require('socket.http')   res, err = http.request('http://IPLOCAL/pub/remote_control?code=CODETELECOMMAND&key=' .. key) end
(09.05.2019, 13:28)admin Wrote: There's no easy way of accessing custom values. But you can create a table with number - key mapping:
Thank you again for your answers.
B.R.
Hi !!!
Please, whear can I put the script for Http POST ??? In Resident ???
I have seen this:  https://forum.logicmachine.net/showthread.php?tid=453
-- empty post body
Thanks in advance for your answer
Regards
It depend of the application but it can be simple event script.
(11.09.2023, 11:06)Daniel Wrote: It depend of the application but it can be simple event script.
Thanks, for your answer
